sorry with my vague posts guys but....
when my 944 was up and running when i turned my steering wheel (in general) it would squeal. and when im driving not so much if at all. just when parallel parking or leaving a parallel parking spot.
i know there could be millions of possible ideas of what could be wrong but ideas and guesses will atleast give me a place to start.
you're either sucking air (you have a leak and/or need to top off the fluid) into the P/S pump or your P/S pump belt is slipping. Take off the P/S pump belt to solve both of these problems. This modification will permanently fix any problems with the power steering.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
It's usually a loose belt, go see how tight it is! If it is loose, tighten it with the adjuster, maybe a total of 3 minutes of work
high pitched whine and hmmm LS swap sounds like it would solve all my issues
fluid is topped off
not sure of where the noise originates. itsa hard to tell since it loud as hell and is very annoying
fluid is topped off
Shouldn't be a high pitch whine. Should be either an intermittent high pitch squeal (under load)..that would indicate belt issues....OR a low to medium pitch whine (under load, even a light turning load), which would indicate Power steering pump failure, usually bearings.
damn, well to update on my cars issues. i have discovered a brake fluid leak from the clutch area (probably the clutch to master clutch hose, or the master to slave hose) so i bought new master and slave and timing belt. bought to buy the balance shaft belt and the two hoses ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
just need to get my car to the mexicans house
