Mystery relay junction...what's your function
heh. so I have a grey relay that's sticking out from the middle of the console on its own 4 wire harness. It's a standard bosch relay. When the key is inserted, it clicks on. What is it for?
This is on a early car.
underneath the dash and into the mess of wiring harnesses hehe.
![](http://www.t-mobilepictures.com/myalbum/photos/photo35/b2/f5/9c928e0d7691__1240148490000.jpeg)
![](http://www.t-mobilepictures.com/myalbum/photos/photo09/61/49/e525660ad6a6__1240148470000.jpeg)
I pulled off the part. some part numbers on here.
VW
321 919 505
SJR
SHIER
07 1000 00
12V max 25Amps
VW
321 919 505
SJR
SHIER
07 1000 00
12V max 25Amps
naw.. not windows. i pulled relay and tested. engine starts and runs, accessories still work: windows, blower, headlights, turn signals, fog lamps. all still work hehe. what other electronics are required for driving....anything? cause this is a track car after all.
Early car right? The only relays not located on the relay board should be:
Windows (the only relay with the part number you mentioned)
Sunroof
Fog lights
Or...as mentioned by others, maybe the previous owner added something.
Sunroof
Fog lights
i just stripped my whole console area in my 85/2 and its not in there!! and i think u have an early car so could be PO installed or early model only stuff.
Not on the board (for early 944) should be:
321 919 505 Electric Window Relay
431 951 253 D Sunroof Relay (1984-85/1)
944 615 223 00 Fog Light Relay
944 615 103 00 Sunroof - Radio Relay (1983-85/1)
111 943 383 C Headlight Motor Relay
That's all the info I have, hope it helps.
