grinding noise when i manual crank......
Old 03-27-2009, 12:05 AM
pwnmastap
pwnmastap's Avatar
Default grinding noise when i manual crank......
exactly as the post says....what can cause that and what may i need to replace?
Old 03-27-2009, 04:17 AM
JohanvdWalt
JohanvdWalt's Avatar
If there is a smell of coffee its perfectly normal.
Old 03-27-2009, 08:27 AM
paulmezz
paulmezz's Avatar
I've always heard you can go blind if you do that....
Old 03-27-2009, 10:56 AM
roman944
roman944's Avatar
Old 03-27-2009, 11:19 AM
V2Rocket
Rainman
V2Rocket's Avatar
lol
i assume youre talking about windows, so pull off your door panels and see whats going on, look at the gears etc, maybe add some lubrication to em.
Old 03-27-2009, 11:27 AM
roman944
roman944's Avatar
or it could be grinding noise when he manually cranks ... THE ENGINE!
Old 03-27-2009, 11:32 AM
pwnmastap
pwnmastap's Avatar
yea when i manually crank the engine i here a grinding noise well a noise in general from the clutch area. i am about to align the marks on the gears and then crank and check for missing teeth on my fly wheel but im just tryin to get a general idea of what it could be.
Old 03-27-2009, 12:09 PM
DarylJ
DarylJ's Avatar
I'm totally confused. By "manually crank the engine", so you mean with a breaker bar on the crank bolt? If so, what do flywheel teeth have to do with anything?
Old 03-27-2009, 12:10 PM
pwnmastap
pwnmastap's Avatar
i hear a noise coming from that area when i manually crank the engine
Old 03-27-2009, 12:12 PM
V2Rocket
Rainman
V2Rocket's Avatar
have your reference sensors dropped in the BH or something?
Old 03-27-2009, 12:15 PM
pwnmastap
pwnmastap's Avatar
not sure dont believe so. ill take a look. but im mostly certain they havnt
Old 03-27-2009, 12:17 PM
krystar
krystar's Avatar
i know when i manually crank the engine in my car, it doesn't grind
pwnmastap
pwnmastap's Avatar
lol hahahha thats funny ****!
Old 03-27-2009, 12:18 PM
krystar
krystar's Avatar
could be your starter solenoid isn't pushing the starter motor fully to engage the flywheel teeth.
roman944
roman944's Avatar
lol wow, I thought this thread was like a joke or something so we get to fill in the blank!
lol @ krystar
Quick Reply: grinding noise when i manual crank......
