Firewall Has Crack at Master Cylinder
I did a search but couldn't find anything. In progress of replacing the Master cylinder I noticed a crack in the firewall (wavy line underneath the hole for MC is the crack - first 3 pics are from engine bay side and the last from interior side under the dash). It looks like someone tried JB Weld at one point and I pounded the firewall to make if flush. Has anyone had this problem...looks like fatigue stress. How did they get it fixed? I'm wondering if I should have a proper shop reinforce the area and do a better weld job than I can do with my flux welder.
Also on a side note...what is this apparatus in the very middle of the picture. It connects to the intake manifold and the wires run into the engine wiring harness. I have no idea what it is. The car is a very early 1983 (1982 mfg date) US 944.
Its common for early 944s to have the CLUTCH master firewall break off. I have fixed 5 of them so far. Welding is difficult as its hard to get in there. The best way is to cut a sheet metal or aluminum much larger than the area affected and bolt the plate on top of the firewall. Silicone the piece but make sure you cut the hole in the right location.
Rainman
is this a possible cause for a squeaking clutch pedal? whether the car is on or off when i push the clutch i get a weird metallic squeaking kinda noise. my dad said it was the throwout bearing any ideas?
Only issue was to adjust the clutch master cylinder rod (filing it down) to keep it from binding against the new firewall thickness.
Thanks - me and a friend were thinking of adding more sheet metal but we were worried of not enough thread to get a secure hold on the master cylinder and the fact that it changes the mounting location.
Monkeys Removed by Request
Yes its common. My car had the same failure. I didn't even ask what method was used to fix it though. He may have just welded in a new sheet over it.
Have you even bothered to open the hood and have someone else depress the clutch with your head near the master?
