HELP!!! '90 S2 Wont Start! UPDATE-It now runs!!!
I took my car to Precision Porsche in Riverside for a clutch, rear main seal and motor mount replacement. the guy finished the clutch and RMS but now he called me and said that the car won't start.
It's got spark and starter, but no fuel I guess, we tried arming and disarming the alarms, the factory one and an aftermarket alpine SEC-8048. The car turns over but won't start still. The Alpine has starter disable, but I don't know if the factory alarm kills the fuel pump.
any suggestions anyone? He wants to charge me for his time troubleshooting an issue my car didn't have before taking it to the shop. Is there anyting that could have come loose relating to the fuel pump when he replaced the clutch??
Help!!!
I'm about 50 miles away and I'm having him check for power at the fuel pump right now. So it's kinda hard for me to do anything other than offer suggestions. I've got Monday off so i may have to get AAA to tow it home so I can fix it if he can't get it to start.
Would it be his responsibility/ fault that it messed up or is it mine??
Thank you in advance.
Ernie
Help!!!
Ernie
The last time I had a problem like that it wasa bad fuel pump...the pump would run but not build pressure in the fuel rail.
I would say it's up to your wrench to figure out why a car that ran before he worked on it won't run now.
If he finds that it's something he has had nothing to do with (I am assuming he's honest like my wrench) then you should pay...otherwise it's on him.
Will the sensor kill the fuel pump? The mechanic says the car has spark...
The speed and reference sensors are located on the bellhousing...which he removed to do the clutch and rms. Now, assuming the car ran fine going in, my best guess is that he messed the sensors up or possible forgot to put them back on. However, he could have also messed something up at the fuel pump since he needed to drop the tranny as well.
Ask him if the tach is bouncing while turning it over. If no...reference sensors. If yes.... I'd look at the fuel pump. Have him check for pressure at the rail.
By the way, he should not charge you for troubleshooting an issue that came up while they were working on it. Especially considering that what is wrong could have been easily caused by his work. After they fix it...at no charge...find another mechanic.
Good luck, I hope it works out for you.
Hey Man
Fuel Issues
Originally Posted by Clarks-Garage
For the fuel pump to start and remain running, for the ignition coil to develop secondary voltage, and for the injectors to fire, the DME computer must see an engine start signal or an engine running signal (greater than 200 RPM). When it does, it completes the circuit for the Fuel Pump / DME Relay secondary coil and the fuel pump starts. It also provides a ground or current flow path for the ignition coil primary and secondary coils. As a result, the current flow through the primary coil induces a voltage in the secondary coil. The voltage across the secondary coil is what is seen at the distributor. The engine cranking / running signal also goes to the injector drivers (2) which provide a ground or current flow path for the fuel injectors to open. The injectors are batch fired which means that all four injectors are fired together. On 944s, injectors 1 and 2 are wired together and injectors 3 and 4 are wired together. However, they are all powered from one injector driver inside the DME computer.
The engine start signal is normally generated by a combination of voltage from the ignition switch to the starter solenoid and a signal from the reference sensor. However, if the starter solenoid signal is not present, an engine cranking signal can be generated by the combination of the speed sensor and reference sensor signals.
If all of the previous tests have been completed satisfactorily, check for cranking signal inputs as described in the following steps.
Not Special
Ernie, I think these guys have it right. Steve, in particular, may have hit this one right on the head (as usual!). But, for your reading pleasure, here's a list of all the alarm threads I was reading while troubleshooting the alarm on my '89. Not all of them will apply to you, but the general information is helpful. It's an html file, but I renamed it to .txt so I could attach it...you'll want to rename it back.
Canadian Yankee
The S2 has one Reference Sensor on the back of the bell housing, not two like the 8v cars. I would agree with everyone else and say I would check the reference sensor first, for proper gapping. He may need to add one of the spacers rings. P/N# 944.101.335.00 or 951.101.325.00. Depending on the gap(0.3 or 2.0).
Thank you all for your suggestions. I'm saving them as PDF's to take to the mechanic's shop on Monday. He never got back to me whether the Fuel Pump was receiving power or not.
I'm going to bypass the alarm and see if that helps. I also want to verify that spark exists.
This is so upsetting. I spent a while looking for a decent shop and I guess I still have yet to find one. I didn't have the resources to do the clutch job at home so I had to farm it out. Now I totally regret my decision. He's got 40 years working on Porsche cars, so I figured it would be ok. I had a weird gut feeling when I left my car, I should have followed it and took back the car. 20/20 and all that. My wife is really ticked off about the call, she wants heads to roll.
Sorry, had to vent.
Once again, thank you all for the suggestions and I'll post back with what I find on Monday.
Sorry, had to vent.
Hi Ernie , I would not be suprised at all that it will be one of the two alarms in the car causing the issue . We come across non standard alarms(fitted to Porsche cars) at our work every week and ever now and then you disconnect a the battery to do a repair job ,say a clutch etc ,only to find when the battery is reconnected(the next day) the non standard alarm does not want to play ball ,and in nearly every occasion there is H/T spark and the engine cranks over normally , but there is no fuel (no power to pump).So there is in my opinion no reason to be upset with the repairer because he has done the following .
A) completed the repairs as requested .
B) tested to see what was present(H/T spark) when the engine would not start and what was not present (fuel pressure).Which means the reference sensor is connected correctly , because if was not there would not be any spark.
c) telephoned quickly to keep you informed
d) has not damaged the car in any way (going by whats in the posts), so I am confused why heads have to roll ?.
The only thing I may have done slightly differently(if there was time) is to isolate the said problem to say a non genuine alarm control unit and temporarily bypassed it to double check , but remember this is time consuming and time(deadlines) may well have been the clincher in the equation .
Note , the standard Porsche alarm is a two point alarm , meaning it disables the ignition and fuel systems , but allowes the starter to crank.
Non stardard (aftermarket) alarms can be one, two or three point alarms , and its also up to the idividual who fits the alarm to choose how many to connect , but most non standard alarms we see are mainly connected via the earth wire to the DME relay only , which means that particular non standard alarm may well have the ability to disable more but was not done .
Regards .BB.
Regards .BB.
I suspect the factory alarm module in your S2 is broken. It's a cigarrette pack sized box behind the DME, under the passenger side floorboard.
The factory alarm module can be bypassed (search Clarks Garage for how) or you can replace with a new one, athough they cost over $100.
When I had this issue I bypassed the DME relay for a few days to start the car, ordered a new alarm module and replaced it myself. Started fine ever since.
Good luck!
Hey Man
Regards .BB.
Regards .BB.
IT'S WORKING!!!!!!
I just called the mechanic. He got my cabbie running!!!!
The problem ended up being in the fuel pump connector. He checked the pump wiring and noticed the connector was loose. He disconnected it and reconnected it and the car started!! He then wiggled the connector and it shut off. He's gonna splice out the connector and heat shrink butt splice it back together. No charge! Now I'm just waiting on a new motor mount and pick-up is expected this Friday!!!
Thank you all for all your input and informational resources. I was interesting reading and I may remove all the alarms and installing a more reliable modern unit.
You guys rock!
I guess I did find a decent mechanic, hopefully the car is awesome on Friday and hope to be sending him work as I need it done.
You guys rock!
