HELP!!! '90 S2 Wont Start! UPDATE-It now runs!!!
Hey Man
I just called the mechanic. He got my cabbie running!!!!
The problem ended up being in the fuel pump connector. He checked the pump wiring and noticed the connector was loose. He disconnected it and reconnected it and the car started!! He then wiggled the connector and it shut off. He's gonna splice out the connector and heat shrink butt splice it back together. No charge! Now I'm just waiting on a new motor mount and pick-up is expected this Friday!!!
Thank you all for all your input and informational resources. I was interesting reading and I may remove all the alarms and installing a more reliable modern unit.
You guys rock!
I guess I did find a decent mechanic, hopefully the car is awesome on Friday and hope to be sending him work as I need it done.
You guys rock!
