Rattle from above driver side wheel well
This rattle has me going nuts. Even with a friend driving me around while sitting in the back, I couldn't isolate it. It sounds like something rattling in the space between outer and inner wall of the rear roof support or down around the sunroof control motor.
It is a plastic/metal sounding noise that appears to be coming from rear support roof area.
I have checked that the drainage tube, the sun roof drive shaft and the wires all appear to be tightened down. I recently installed new rear hatch struts, but it still hasn't gone away.
Anyway, the hatch seems tight and has a good seal...
But I am at a loss. It started after I replaced the rear shocks, but it's not coming from underneath the car. I am certain of that.
I need some help isolating this
I just got back from a drive to better isolate it... I'd stick my had on the rear glass and it made zero difference to the rattle. I also drive with the door open to make make sure it was coming from outside.
It sounds like it is coming from the area of the rear quarter panel where the sun roof engine is. But that seems tight. I tried pushing the suspension up/down but couldn't repro the noise... I only hear it when I go over bumps though probably only 80%. And the speed of the car can be as little as 5mph or slower as I pull out of my parking garage.
I am really at a loss to further isolate this.
If it is the hatch delaminating, is there a test? I tried hitting around the glass but it all feels solid and no noise.
I doubt it. I had the exhaust drooped and fixed recently... the noise was there before the exhaust was fixed. However, it did start after I replaced the shocks. But due to the location of the noise, it really sounds like it is in the passenger cab, I am reluctant to believe it is suspension related -- this driving with the door open...
But, like I said, I am open to diagnostic ideas...
For example, what does a rear hatch rattle sound like?
Loose nut in drivers seat is my vote... Sorry couldn't come up with anything better, Try sunroof adjust, lift it slightly and see the the rattle goes away, my N/A rattles from the SR if conditions are just right, new seals should clear this up if it is the culprit...If it was the rear hatch you would know it... read my OT on it, I am in the middle of a rear hatch re-seal....
It is intermittent, but does rattle with bumps that may or may not cause the suspension to move noticeably.
I am really really hoping it is something I have over looked that is easy to fix...
I have had both rear tires off and torqued 2 times in the last 2 months since the I did the rear breaks ( I was sent the wrong wear sensors, and I finally got the correct ones 2 weeks ago).
Hi, I may have missed what type of car you have so I will assume its a 924/944/968. This rattle sounds like a common problem found on these models. It is likely to be a Corroded Trailing arm bolt. Check all of these. as they corrode play forms and that clunking noise starts, the fix is generally simple, remove, clean and replace. Probably best to put the car up on a lift to have a good look at all of the bolts and test tighten them all.
Both my cars have rattled from the hatches, and made different sounds. You might be able to climb back there again, and push upward on the hatch, appying pressure near the top edge corners. This should make the noise stop, until you release pressure.
And yes, it is a 944 S2.
Are any of the seat pins loose? The things that look like door strikers and hold up the back seat? They are held in by 2 or three screws (in the plastic around them) that goes to a piece of threaded bracket that sits behind the B post.
I also took a cloth and folded it several times and placed it around the hatch pins too to see if I could either elimintate or change the sound. The cloth around the hatch made no difference.
Tonight, I am going to have someone drive me around again, but I will be lying down next to the sound.
I am baffled... litterally.
