Head Deck Spacer
@ van: Yeah - the change in bore is not helpful to those looking for factory FI bits. However it does mean that an S2 head (maybe even 968?) would drop straight on. That's another story...
@rogue: The Eaton M90 has a helical rotor - adiabatic efficiency is higher than most Roots type superchargers, nominally around 60%, but that changes through the RPM range. Poor mans solution would be the unit fitted to the Mazda Millenia as standard - but more a twin screw design than the "twisted rotor".
Small Business Partner
Monkey,
Yep I'm familiar with the Eaton units. You could probably even get an HH unit (high helical), if you want. I also have a lysholm twin screw from a millenia waiting for a rebuild sitting here...
Regardless both units offer lower adiabatic efficiency then a decent centrifugal compressor. I would plan on using an intercooler. The stock 951 piece would serve you well.
-Rogue
-Rogue
Eaton m90 - I reckon it will manage up to the power level I'm looking at... see http://www.eaton.com/ecm/groups/publ.../ct_128485.gif and Blown944's posts for more details.
Has a reasonable adiabatic efficiency for a rootes type although not as efficient as a lysholm or whipple. Problem with the later however is their capacity and the speed they need spin to achieve your goal.
Depending on your particular goal, be it XXX Hp, 1 bar boost, or more mid range torque and resultant driveability
for a street car it may be worthwhile considering a centrifugal SC. They have a much greater efficiency at higher RPM, but obviously the compromise is low and midrange. With my basic SC14 on a 2.0L the boost is fairly linear from 1400 to redline. However the goal was not max HP but rather smooth useable torque throughout the entire rev range. Acceleration is virtually instant, well < 200 ms, and has similar to V8 grunt driving around town. Not a race car, merely an enjoyable and quick street car.
And I do have a plan - it's very well formed and accounts for contingencies based on the fact that this is a learning experience for myself. If I knew exactly what I was doing it would be a lot less fun! Incidentally you are currently located in the middle of the research phase of the plan The build stages might go something like this;
1. Blower, injectors, fuel pump, RRFPR, thicker gasket and stock ECU. Wideband (LM2) also. Low boost - 7psi
2. MicroSquirt and ignition/fuel fine mapping, knock sensor. Medium boost - 10 psi
3. Water/Methanol, FMIC or water/air IC, High boost - to maximum efficiency of blower (15psi?).
How do you intend controlling the ignition curve with a stock ECU?
An IC is an absolute necessity at any usable boost level IMO. Data logged IATs over 60*C above ambient with just a quick blast off the lights with no IC. A major contributing factor to detonation. Sure that`s on a SC14 (82 CID) at 8PSI into 2.03L but a M90 overdriven to produce 15PSI into 2.7L won`t run any cooler.
Well - if you have money to throw away before thinking your way through a problem you might go ahead and believe that... Please bear in mind these would be custom 104mm bore dished pistons - and would cost as much/more than the rest of the components put together. Blown944 has proven that the stock bottom end can handle the power, and a gasket/spacer was a potential solution (not a new one) to the problem. The true cost of a successful installation is measured in patient hours of research rather than $$$.
Besides, if everyone did things the same way... there would be no blower installations in the first place? (everyone would "sell the NA and buy a turbo")
The Cometic engineer seemed happy to entertain the idea of making a custom gasket (see the "custom gaskets" section of their site). Just not the thickness I had in mind initially...
Sorry if I came across as a nay-sayer. On the contrary.
Of literally hundreds of posts commencing "I want to SC or turbo my NA" there is only a handful of guys that have actually brought it to fruition. Sincerely wish you success with this project and will be following your progress.
Roger
I was thinking, you'll probably need an adjustable cam gear, since the valve timing will change as the pulleys move farther apart (because of the fixed tooth spacing on the timing belt.)
The roots type are pretty popular these days and the Vette crowd has been eating them up. I personally do not want full boost on my ZO6 @2K rpm's since it makes more low end TQ then is reasonably usable which is why I'm going a single turbo route. Maybe it would be nice on a 44 but then you have intercooling difficulties that eat up dollars quickly to resolve.
Well, the Cometic gasket tech replied and said he'd recommend up to 0.08" thickness. That's 0.04" ~= 1mm over stock, which equates to about 9.5:1 CR.
So, a reduction, but perhaps a better compromise.
I'll post more when I'm not at work!
Rainman
we could use the torque
