IFC fiberglass hood
#46
I had a busy day today... I got to work more on my hood.
Here are some pictures from where I left off. (After the pictures is a cool video showing how I epoxied the latches on.)
And, here's the video - you'll see my project manager's older brother performing QC (quality control). (He doesn't like the noise of the air compressor.)
#53
I got the hood back from the body guy today. Just put a prop rod on and got it on the car here are a few pics.
Note: I haven't done the final fitment or adjusting yet - so don't comment on the gaps!
#56
From Sunset Porsche - $15 (there's a rubber grommet and a clip, too. I'll see if I can dig up the p/n's.)
The hood was painted off the car (I assume you mean the hood hinges?)
#58
Ahh, they're a little bluish on the inside when they're opened because the body guy used a blue polish. They'll be closed most of the time!
#59
Very impressive work Van, any more picture of the hood prop (where it mounts to body) and how it lays with the hood shut? I need to repaint my hood and want to add heat extraction vents on both sides. Now seeing how good the IFC hood fitment is i think i may go this route instead and use the same method for hood latching also.
BTW, here is the part # for the hood prop and rubber piece
477.823.363.A
171.823.395
477.823.363.A
171.823.395
#60
Yep, those are the p/n's. You also need: 431.823.397 - this is the little metal clip that holds the rod onto the hood when the hood is closed.
I had to fabricate the mount that's on the body.
I'll upload more pictures later today.
477.823.363.A
171.823.395
477.823.363.A
171.823.395
