Yeah, another oil question
Does anyone make a 10w-50 oil? I have Mobil 1, 15w-50 for winter, but the oil pressure is still not building as quick as it should on cold starts.
Just finished my winter oil change, 5w40 Rotella, used this the last couple of years as the 20w50 VR1 I run during the summer is way too sluggish on cold morning start ups.
The first number is the viscosity at temp, the second is the viscosity when cold, if xx-40 were to cause issues it would be when cold, not at temperature...You may have bigger issues.
Administrator - "Tyson"
I ran Castrol 5w-50 in my 944S for the first few years of ownership. Never driven in winter, did see sub 30 degree temps in the late fall.
It did throw a rod bearing a few years later though.....
Never seen a 10w50 dino oil, seen 5w50 in synthetic.
