New springs didn't lower car????
1 Post
I just installed new 200# weltmeister springs on my '87 924S and expected about a one inch drop, seeing how the new springs are atleast an inch shorter than the stock ones. but the ride height didnt change.
was there some kind of adjustment that i need to make?
how high should the top of the strut stick out of the upper mount bolt? before the swap i had 5 threads showing, so i kept it that way.
thanks,
Justin
thanks,
Justin
Unbannable
Give it a couple days of driving to settle before you worry about it. Almost every time I have ever lowered a car, my first thought was "It looks the same". The one exception was when I briefly installed a used uber-slammed system on my Jetta.
BB.
BB.
Former Vendor
Have they settled?
You may want to loosen the mounting bolts while the car is static and then re-tighten. Sometimes that helps. I have sold several sets that don't lower some cars, but do others with no real explanation why. My last adventure was with a 997 C2. H&R's didn't lower it as much as they were supposed to, but Eibach's did. Still don't know why......
1 Post
guess ill just burn up some gas for a week on my favorite (twisty) roads and see what happens.
if its gonna change it needs to be fast, cause im lookin at tires with a smaller sidewall, and i dont want the gap to get any bigger.
beerburner, how far away is Sterling from the peninsula?
Unbannable
I figure I'm about four hours from you in northern VA. And if your springs were sagging, you'd get whatever benefits you'd get from the change in spring rates. Unfortunately, I don't know what the stock rates are so I can't comment...
BB.
BB.
1 Post
and i had planned on lowering the rear via the eccentric adjustment after i did the front (technically still not lowered) and as soon as im clear on how to do it.
i couldnt find any pics in past threads... i need pics.
