All Crank No Fire
#31
Resistance is Futile
Since Pete's tied down tonight with the GF unit...
We did a flyby 15 minute troubleshooting effort:
Fuel flow: check
Re-inspect cap and rotor: check
Pull injector plug and check for voltage on ignition attempt: FAIL
Interesting.
Testing his coil in my car for kicks. Give me 20. Make that 45... boss just announced my Fatherly duties for the evening...
Fuel flow: check
Interesting.
#33
Noid light time. And while you're in your car, you might want to rip the DME out to put in his
#35
Check to make sure you are getting fire from the coil and fuel pressure in the rail.You need to figure out what you are not getting,fire,fuel or air!
jamie@944online.com
jamie@944online.com
#36
BTW, you can tease the wires apart and crank the car to see if the fix works, before doing any soldering. If any one of them is shorted, it wont work though, so you have to check all 4 to be sure.
#43
DME...mine was the same thing...even bought a nother off ebay...when that didn't work i spent a month replacing parts till i voltmetered both sides of the DME and found signal going in...no signal coming out. new DME later popped right off...then started on fire. but it still started!
