Putting New Engine In 1986 NA 944
Old 09-28-2008 | 02:22 PM
rawwarden's Avatar
rawwarden
Default Putting New Engine In 1986 NA 944
How high do I have to life the car to drop the engine out of it?
Old 09-28-2008 | 02:27 PM
Calmchaos's Avatar
Calmchaos
IIRC you need 26" of clearance.
I think that's what Haynes manual says.
...you have to lift it up super far. lol.
GL!
EDIT:
Answer is: >21"
Old 09-28-2008 | 02:33 PM
ritzblitz's Avatar
ritzblitz
Cant you bring the motor out the top on these cars?
Old 09-28-2008 | 02:34 PM
V2Rocket's Avatar
V2Rocket
Rainman
yea but its harder lol.
you have to kind of angle it to drop it in right and get it past stuff like the brake booster.
thats what i did
Old 09-28-2008 | 02:35 PM
Calmchaos's Avatar
Calmchaos
That brake booster is an a$$hole!
Old 09-28-2008 | 02:41 PM
krystar's Avatar
krystar
oh damn is it 26"? I thought it was 22" doh i gotta jack up some more hehe
i'm at the step of disconnecting the crossmember from the engine mount.
Old 09-28-2008 | 02:43 PM
Calmchaos's Avatar
Calmchaos
Hmm.... 22" doesn't sound right, but I'll try to find the correct number for sure.
EDIT: Clarks Garage
The engine is removed from underneath the vehicle so at least 21 inches of clearance is required
So 22" is correct!
Old 09-28-2008 | 07:21 PM
krystar's Avatar
krystar
phew hehe. i'm saved. i don't know if those jackstands will go higher hehe.
Old 09-28-2008 | 08:46 PM
Calmchaos's Avatar
Calmchaos
I jack mine up to 26" because I put a cart with wheels under the engine and roll it out.
Sorry about the confusion.
Old 09-29-2008 | 10:57 AM
Will Feather's Avatar
Will Feather
Ive pulled 2 motors from the top, not very hard IMO, just gotta remove the power steering pump. Ive never dropped one from the bottom though, next time!
Old 09-29-2008 | 02:38 PM
M758's Avatar
M758
I think out he bottom is easier.
BTW... you can use the engine hoist to lift the front of the car higher once the engine in the ground.
I usally do it with rear wheels on the ground.
Old 09-29-2008 | 02:51 PM
golfduke's Avatar
golfduke
bottom is definitely easier. What you do-
Raise it about 15" so you can get underneath and work on it. Once the engine is free, drop it to the ground on some cardboard. Remove the hoist and attach it to the upper front crossmember and raise the car. Slide the engine out on the cardboard.
I've done removals 3 different ways including the above method-
-The top was a major PITA- needed to remove alternator, AC, and master cylinder as well as the hood.
- the bottom with the car on stands at 22" was okay, but the top of the engine bay was a bit too tall to work in comfortably for me.
Quick Reply: Putting New Engine In 1986 NA 944
