Someone clear this crap out of my garage!
ok seriously this time i need to rid my garage of some serious overflow or im just going to pile the truck up and head to the scrap yard. I'll make a package deal to anyone wanting to pick this stuff up- preferably pick up anyway. ANYTHING W/O A PRICE IS BEST OFFER!!!
i have four blocks- one has pretty good bores with only 1 small scratch- others are scratched up
front/rear bumpers for GUARDS red n/a
rear bumper side plastic pieces in red
lower front valance w/ foglights for GUARDS red n/a- no cracks but paint is flaking alittle at the bottom $100 obo
three cranks- each one would need to be repolished or turned from mild spun bearings
three oil pumps
Cluster surround trim w/ good vents
center console TRIM shifter surround- the one w/ sunroof switch placement
cubby under radio
factory blaupunkt radio am/fm works from 87 n/a
cheapy air/fuel meter-NOT wideband- w/ homemade plate to replace cubby
two N/A intakes - one painted black- one stock-
n/a AOS
N/A J-boot
n/a AFM-works
Driver's side red N/A fender- good shape
VENTED nosepan from a 931- will bolt right onto an N/A- painted red but has some slight damage that was fixed not too bad- $100 w/ vents and badge
stock n/a nosepan in primer
two stock rear hatches
black late dash w/ some cracks-lower is good
dash trim- yeah
all kinds of a/c brakets, ps mounts
door windows
TURBO engine mount-drivers side that the compressor mounts to
early balance shaft covers and shafts
pulleys- how many do you need?
Turbo Downpipe- good shape
black sunvisors
turbo 26.8mm front swaybar w/ drop links etc...$125 shipped
small rear stock n/a swaybars and a front....small.
nice stock rear droplinks
rear hatch motors
rear side panels-covers rear speakers - two sets both black
PS early a-arm
n/a cast manifolds...
bumper shocks
horn set
turbo front brake backing plates X4
turbo strut mount air deflectors X4
black ebrake handle late
entire flip up headlight assy- linkage, buckets, lids,motor etc....
turbo oil cooler plate - for remote mount oil cooler-just the part that bolts to the block w/ filter
2x sets of speakers- 4x6 - cheapy set of NEW replacement speakers and a set of nicer component speakers
n/a rear brake calipers w/ pads
three oil pumps
cubby under radio
n/a AOS
N/A J-boot
n/a AFM-works
dash trim- yeah
door windows
black sunvisors
rear hatch motors
PS early a-arm
bumper shocks
horn set
im in cheviot- 45211 zip- just a couple exits north of downtown cincy- yes i still have it
i have an 86 n/a block that is pretty decent w/ one small scratch in one liner- it was steam cleaned for me as well as the oil pan to make sure everything looked good after a spun bearing.. i also have balancers, covers, a turbo downpipe, oil pickup tube, oil pump, engine mount that the turbo sits on, pulleys, belt covers, some heat shields etc.. i'd have to really look.
-CRANK- all cranks are from 2.5/2.7 - i believe the one is from my old motor just needs polished out from sitting. Heavy and expensive to ship i'd be though. Lemme know.
