tail light lenses
tail light lenses
my 91 s2 appears to be vomiting some kind of black gasket material out and around the tail lights. im sure its from heat and time but is the seal broken on the tail lights or is this material a sealent between the tail lights and the body. plus this stuff has proven extremely difficult to remove from the paint
its the nastiest f*ckin goo you will ever encounter
its generic 3M weatherstrip adhesive or something similar, its a real mess to work with...should be available at any local parts store
As mentioned by others, this is 3m Strip Caulk or equivalent. It is used between the tail light assembly and the body, there is no "lens", just an assembly. Although it is unlikely some expanding caulk, probably from the heat, has broken the seal, simply pull back the carpet on the inside while squirting carefully with a hose on the outside to check for leaks.
jmd_forest
jmd_forest
