Im stupid, stupid.. retarded..
i was putting in a smaller batter for electronics tests... now imagine the worst thing that you can do with a battery and a car..
while tightening the bolts on the leads, i managed to drop the motherf***ing wrench, it fell and welded the + and - leads... in most cases that means the car's chip is fried... please tell me porsche is different and that doesnt happen... please????
Only 1 way to find out... fire it up!
I don't think you did any damage. I don't know why Porsche used a battery where the + post sits next to/under the windshield frame, but I have sent some sparks flyin myself when hooking up jumper cables, and no ill results....
no, its fine if the + hits the frame, not much damage done... what i did, in every other car, just destroys it... one battery point to the other ugh, and i can't fire it up cause im waiting for my fuel pump...
the only good sign is that when i turn the accesories on the windshield wipers dont go crazy as the horn randomly honks..
Caused some sparks once when the + terminal arced with the hood. Car still started up with no problems. For peace of mind, consider a terminal cover for the + cable. Marine stores have larger ones that can accomodate the 3 cable stock terminal.
Hitting the negative terminal and hitting the body is the same thing....they're both grounds.
And +1 on the real damage is hooking the terminals up backwards.
If it makes you feel any better, the first thing I thought of when I read the title of your post & and your first line was:
"Oh damn, he shorted it, started a fire, and burned it to the ground."
Glad it wasn't that. . .
