Anyone interested in a 944S2,968 turbo system?
#31
Captain Obvious
Not that I am speaking for every NA owner here...but that's pretty darned expensive. It'd be smarter to buy a good 951 with mods for that kind of $.
My .02.
My .02.
#32
You may have also overlooked the fact that this is not a kit for the 944NA but rather for the S2 or 968.
-Joel.
#34
Captain Obvious
I guess you could say same goes for 944 to 944S...or any car. Good point. maybe I'm a cheap SOB then.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
I'm not that sharp when it comes to a turbo system, but are all turbos intercooled? I had a Dodge 600 turbo when I was in highschool (yes, I was a geek) was it intercooled too?
Can a turbo run without an intercooler?
#36
plus look at the price of a turbo kit for bmw or other highend car...for quality parts on a not so common car and considering the kit components i think its a high but reasonable price.
#37
Can a turbo run without an inter-cooler?
There are quite a few Diesel pick-ups on the market without inter-coolers on which aftermarket coolers are fitted with around 20% increase in power.
Johan
#38
of course, those engines were based off of Yamaha R6 engines (12.8:1 comp ratio), and were designed to spool as quickly as possible (getting low end torque out of a restrictor-plated 600cc inline 4 is a bit of a trick hah). The engine ran on ethanol, which helps cool things down too, and I determined that, for the boost we were running, the pressure drop and flow restriction from adding an intercooler outweighed the benefits of being abel to turn the boost **** up higher.
If you're using a different engine and have different goals (eg peak hp vs. width of torque peak), YMMV
#39
There's PLENTY of room in an S2 or 968 for an intercooler if you replace the gigantic airbox with a cone filter. That would certainly be a no-brainer for me, if I were to turbo my 968.
#41
While I don't have an S2 or 968, if I were to turbo my car, I actually probably wouldn't intercool it. Reason being that I wouldn't do anyhting other than a low boost system (max boost 5-6 psi). I would do this so I could size a turbo for a broad powerband and avoid putting too much excess strain on the drivetrain. The airbox would probably go though and I would mount the turbo on the pass. side like Callaway did
#42
also curious about this.
Is there any way a low boost 6-7psi system could be developed or put together. Maybe using 951 parts and such. What would be needed to bolt the 951 turbo to the S manifold? Could it run off the s DME or would it need the turbo DME?
944, 944s2, 968, buy, cai, cat, controller, fuel, inletdrain, kit, s2, sfr, supercharged, supercharger, turbo, valve
