Put the motor back together with pics... and a surprise
Old 08-01-2008, 10:03 PM
halik
halik's Avatar
Default Put the motor back together with pics... and a surprise
Gasket matched and polished head, magnecor wires, cone intake, bosh platinum plugs and whole lot of cleaning:
and as for the surprise... when I was trying to start it, I had absolutely no fuel pressure. So off to the gas statation i got since the tank was sitting on empty. Fill it up and what do I find ??
THERE'S A MOTHERFCKING CRACK IN MY MOTHERFCKING GAS TANK! /samel jackson
Crap... off the to the junk yard I go.
Old 08-01-2008, 10:06 PM
PorscheDoc
PorscheDoc's Avatar
That is just the cover to the fuel pump, and you sure you don't have a hose or pump leaking on the other side of the cover?
Old 08-01-2008, 10:10 PM
halik
halik's Avatar
I haven't actually taken that off... it's getting dark out and I couldn't see much, except the leaking gas. I'm crossing fingers that it's something like that. Does anyone have any diagrams of gas tank assembly?
Old 08-01-2008, 11:54 PM
SamGrant951
SamGrant951's Avatar
Theres not much to it when you pull that cover, i think you will be ok - let us know what you find.
Old 08-01-2008, 11:58 PM
Yummybud924
Yummybud924's Avatar
did you rebuild the motor or just painted everything red? lol. I'd get the fuel leak checked out right away, you don't want to blow up.
how does the car run on platinum plugs? I was told to just use copper and not the fancy platinum ones. I was using bosche copper and switched to ngk v groove coppers not sure if they're better but it runs good.
Old 08-02-2008, 01:21 AM
Erzengal
Erzengal's Avatar
Copper > Platinum.
You did all that work to the car, yet the rest is in need of a good scrubbing! Toss in a new Expansion and Washer Tank, then the Engine Bay will really be shiny!
Old 08-02-2008, 01:24 AM
m73m95
m73m95's Avatar
Its the Fuel pump. Mine did the same thing.
I think modern fuel with ethenol eats the seals in the pump. My pump worked fine, but bled like a stuck pig from around the plastic front.
no big deal. Its easy to change, and cheaper than alot of other fuel pumps. http://www.rockauto.com
Old 08-02-2008, 03:32 AM
marksportcts
marksportcts's Avatar
It's just the fuel pump cover/mount. Easy to replace. Check the hoses as well.
Old 08-02-2008, 10:03 AM
halik
halik's Avatar
Originally Posted by Erzengal
Copper > Platinum.
I know, where the car sits right now I have no water hose access so I had no chance to scrub it all out. It's definitely on my list, along with the two tanks
Old 08-02-2008, 10:33 AM
JonH
JonH's Avatar
What do you think of the cone intake?
Old 08-02-2008, 10:37 AM
harrisonrick
Captain Obvious
harrisonrick's Avatar
I'd add more inlet tubing and direct it to get air from the hole in the fender. Otherwise she'll be getting warmer air, and you'll actually lose HP.
There's a ton of write ups about this. The average response will be, use the stock box, maybe add a K & N element and go.
Old 08-02-2008, 11:04 AM
Yabo
Yabo's Avatar
Mine leaked at the fuel line coming fromthe pump there.
Old 08-02-2008, 01:11 PM
halik
halik's Avatar
It was a rotten fuel line going from the pump to the filter... yay!
Old 08-03-2008, 05:43 AM
76 911s
76 911s's Avatar
This is only partially true. I put a digital thermometer behind my hood latch found that the temperature was the same as ambient (I was trying to see if the MAF on my 951 would be sucking hot air) at highway speeds. While it no doubt sucks hot air in traffic/stop and go, once on the highway, plenty of air flows through. Now whether or not it increases HP is another story....
76 911s
76 911s's Avatar
This is only partially true. I put a digital thermometer behind my hood latch found that the temperature was the same as ambient at highway speeds (I was trying to see if the MAF on my 951 would be sucking hot air). While it no doubt sucks hot air in traffic/stop and go, once on the highway, plenty of air flows through. Now whether or not it increases HP is another story....
Quick Reply: Put the motor back together with pics... and a surprise
