Gearbox questions.
howdy everyone.
i currently own a 1979 924 with M471 option group.
I bought the car in the midst of modification, and i am going to go slightly beyond the previous owner in terms of engine.
i am got the car with some engine mods done, but i am adding dual valve springs, aluminum retainers, and a cam grind (hardened of course).
my powerband goal is the 4000-7000rpm range. (basically a hot street/autocross car).
my issue, however, is with the gearbox in the car (the 016Z snail shell).
what i am looking for, is a way to optimize the gearing for the new powerband. the stock gear ratios are just too tall, especially for a car with its powerband shifted up 1000-1500rpm.
what i am wondering, is if anyone knows of any alternate transaxles, or at least of any alternate final drives.
ideally, i'd like the ratios tightened up a bit. ive been playing with numbers, and one good alternative solution is to use a ~4.55 or so final drive, with the stock 016Z gear ratios.
or i can use the 79 924 Turbo ratios (which i find to be "slightly" on the tall/wide-spaced side, but not as bad as the snail shell).
i have a few ideas.. but i wanna see what everyone else thinks would work.
I don't know of any Audi 016 trannys that used a shorter final drive than 4.11. You might try searching the Audi boards.
Looking at your ratios, I don't think your problem is so much the final drive as the extremely wide gear ratios they put in your box. It would be a lot more work, but what about swapping out 3rd, 4th and 5th gear sets from a late/ROW 944NA tranny? I believe they would fit, and would result in a much closer-ratio box:
ratio___79 924 ___88-89 944NA
1st______3.60_________3.60
2nd______2.13_________2.13
3rd______1.36_________1.46
4th______0.96_________1.07
5th______0.62_________0.83
F.D._____4.11_________3.89
Definitely would be an improvement, but I don't know about bang-for-the-buck.
thats exactly what i was thinking, but i wasn't sure if the 944 gears would fit.
by the way, the 1979 931 does have a shorter final drive (and taller gear ratios).. but the problem there is that the final drive is too short (5.000). the ideal ratios for what i am going for actually is the late 944 N/A ratios. are you indeed sure the gears will fit onto the shafts in the 924 gearbox?
have you looked at:
<a href="http://www.924.org/techsection/7transaxle.htm" target="_blank">http://www.924.org/techsection/7transaxle.htm</a>
where much of this is discussed?
also this thread:
<a href="http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic;f=15;t=019690#000011" target="_blank">http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic;f=15;t=019690#000011</a>
btw...you may notice a few responses from Scott Vaughan in that thread...he also has the website:
<a href="http://www.924.org" target="_blank">http://www.924.org</a>
also this thread:
I understand that the gear sets swap between 944 and 951 boxes, but I am not sure that they swap with your 924 gearbox. I would expect them to, since they are all Audi 016 boxes, but I don't know how you would verify this.
I have never seen the ratios for a 931; wow, thats a low FD! I guess that helps them get out of the hole with some turbo lag. However, if you can fit those 5.0:1 gears in, maybe Audi made some intermediate sets, like 4.5:1, for their 4000 series cars. Certainly would be an easier swap that three gear sets within the tranny.
i got my gear ratio information from this link:
<a href="http://www.924.org/Downloads/PorscheTrans1.xls" target="_blank">http://www.924.org/Downloads/PorscheTrans1.xls</a>
the transaxle in my 924 is the 016Z transaxle (it is not listed in that spreadsheet).
the gear ratios for 1-4 are the same as the 016/9 audi gearbox, but with a taller 5th gear (0.60). it is a snailshell gearbox as well.
ok... just a quick question. will the 3-5 gearsets on a 1986 944 N/A work on a snailshell gearbox from a 79 924 (016Z transaxle)?
I have a friend locally with an 86 944 with a damaged final drive. I was going to suggest an idea to her that she can buy a used 944 transaxle on ebay or something, and then i can buy her broken transaxle to utilize its 3-5 gearsets.
or alternatively, can i use my 924's final drive to replace the broken one in the 944.
hmmm..
<a href="http://www.924.org/techsection/transapps.htm" target="_blank">http://www.924.org/techsection/transapps.htm</a>
says "The 016/Y and 016/Z are US and Euro spec versions of a Porsche transaxle identified by the gearset in front of the differential"
the 944 'audi' 016 gearset is behind the differential
