What is the "Best" Transmission Oil?
Old 06-04-2008, 01:05 AM
  #31
ArcticSteve
ArcticSteve's Avatar
Originally Posted by Chuck 951
Royal Purple --- will fix your problem if not too far gone. You can get it at a NAPA store.
Chuck 951
I dunno I just filled up my 90 S2 with Redline 75W90 GL 5 "Gear Oil" after reading Clarke Garage's take that GL-5 oils were preferred. hmmm
I have already put Redline 75W90 NS in my 87 924S thinking great; a transaxle GL5 oil just for non slip diffs. hmmm
So does an S2 tranny have within it brass or bronze materials? Is this a known factoid?
If that's the case I just might go with Royal Purple's MaxGear 75W90 because they explain their product better. It might be BS, but it sounds good.
Synslide additive technology, Royal Purple's tough, EP lubricating film, provides maximum protection under boundary lubrication conditions typically caused by heavily loaded, slow speed and / or shock load conditions. This tenacious, slippery film significantly improves lubrication and reduces wear by increasing the oil film thickness and toughness, which helps to prevent metal-to-metal contact in gears and bearings.
Synslide additive technology is noncorrosive to gears and bearings, including case-hardened gears that are easily pitted by conventional sulfur-phosphorus EP oils.
Old 06-04-2008, 08:19 AM
  #32
roman944
roman944's Avatar
so what's recomended for a 944?
since mine is on jackstands waiting for bearings, might as well undo 1 bolt and change the transmission fluid now, I think
mine is an early car, but I'm unsure of what Porsche calls for or what will work; all parts stores here have mobile 1 75-90 but I've looked around and some people are saying it can be bad for syncro's
and when doing a search, all answers I'm finding to the topic are "go do a search" but no definetive answer ...
Old 06-04-2008, 11:33 AM
  #33
M758
M758's Avatar
Redline Heavy shookproof. I use this in my 944 spec race gearbox (open diff) and 944 turbo S street car box with LSD.
Old 06-04-2008, 12:02 PM
  #34
sergiomartins
sergiomartins's Avatar
I've tried Swepco 201, RedLine 75w-90. And now i put Castrol SAF-SG 75W-140. i find it very nice.
Old 06-04-2008, 12:29 PM
  #35
roman944
roman944's Avatar
yes, but are you guys on early cars? or it doesn't matter?
Old 06-04-2008, 03:01 PM
  #36
indyryder3x
indyryder3x's Avatar
Mines an 83 w/ 84 trans, try the MT-90, you will be very happy
Old 06-04-2008, 03:06 PM
  #37
dacula951
dacula951's Avatar
I don't know if the S2 tranny has brass or bronze materials, but I suspect if Porsche's recommendation is GL-4, then it likely does.
As for the recommendation in Clark's garage, it is easy to assume that GL-5 is backward compatible to GL-4 requirements because it's that way for many other lubricants (API ratings on motor oils and Dexron I-II-III). It wasn't until I spoke with a Penzoil engineer some 15 years ago that I found this wasn't the case with GL-4 and GL-5. This is confirmed in Redline's documentation.
Old 06-04-2008, 05:23 PM
  #38
544DRS
544DRS's Avatar
I just ran out and purchased three bottles of MT90. Now, if I could only get the drain plug loose!
Nick
Old 06-05-2008, 12:33 AM
  #39
Yummybud924
Yummybud924's Avatar
I used swepco 201 and it grinded in the winter. Then I tried mt-90 with one bottle of litghtweight shockproof and now no more grinding ever, even when cold.
Old 06-05-2008, 09:47 AM
  #40
martin944
martin944's Avatar
Originally Posted by jstand22
Swepco 201
Old 06-05-2008, 09:39 PM
  #41
Yabo
Yabo's Avatar
shockproof says not good for syncro style transmissions.... Isn't that our transmissions? I'm debating over just mt90 again or lightweight shockproof
Old 09-10-2008, 09:00 AM
  #42
roman944
roman944's Avatar
never updated this, but my car now has Redline MT-90 transmission oil and 20w-50 motor oil
give it a few days and you'll notice the difference with every day that goes by, if this is 1st time you are doing this!
/necro-bump
and a question: for winter, should I change the oil again to something different? car only saw about 300 miles after the oil change
Old 09-10-2008, 11:39 AM
  #43
Funn944
Funn944's Avatar
I've been using Royal Puple for over a year. Seems to work well, but won't fix a grind on a quick 1st to 2nd shift. Shift a little slower from 1st to 2nd.
Old 09-10-2008, 12:12 PM
  #44
roman944
roman944's Avatar
are you guys with "grinds" short shifted? because mine is perfect, but I do take it easy with shifting after I lost 1st/2nd/R in my A6 (and I believe it to be due to having a shifter improperly installed by my cousin_
Old 09-10-2008, 01:33 PM
  #45
alordofchaos
alordofchaos's Avatar
20w50 is OK down to about 20-30 Fahrenheit startup temps. Switch to 10w40/50 or 15w40/50 when night time temps get below that.
Your engine will be noticeably slower when cranking, when the oil gets too thick for the temp
Quick Reply: What is the "Best" Transmission Oil?
