My DIY Dash thread (zillions of pics 56k beware)
Good luck. It's a serious pain in the *** to get all of the templates to lay nicely. Then once stitched together, it's an even bigger pain to wrap the dash. We went through 2 covers before the final results, which still is no where near as nice as Rob's dash cover option.
I will say it was a fun experiment though. If I had to do it all again, I'd either:
A. Save my pennies, and send a dash to Rob for his treatment.
B. Go the SEM route.
Do you have more pictures of that sewn dash. I'm also doing my own, and would just like to see how yours turned out.
Rainman
my original plan was to just sand down the original vinyl to get the cracks flush and then put another layer of foam and then the new vinyl but it would be really thick so i decided to strip it.
Great documentation Spencer!
Years ago I had a 914 parts car that had Great Stuff in the rocker panels... it was "structural foam" - and did a poor job at that!
Rainman
still debating on that, i tried to form some spare vinyl yesterday and it was absolutely noncompliant, but then again this was spare stuff from recovering some chairs lol.
id looovvvee to have the french seams because they look so nice and my seats have them so they'd kind of match. i spent most of yesterday making some pretty accurate templates out of paper and cardboard and ill make a preliminary dash cover out of extra marine vinyl (i have tons of the stuff) to see how well my sewing is and how well it fits and adjust accordingly with the real stuff.
You might also notice, we did the same treatment to the center console
It's not the best looking, but hey, it only cost about $30 to do this.
![](http://i165.photobucket.com/albums/u42/Po924S/viynl1.jpg)
![](http://i165.photobucket.com/albums/u42/Po924S/Frenchseamsjointurn.jpg)
The two pieces of vinyl were cut in a 7 shape, that flowed with the console, then they were stitched together, to where it only took minimal stretching to get it to flow right.
With what I'm seeing in your image, you might be able to work the wrinkles out with heat. But otherwise, it looks like you took a relatively straight piece, and attempted to make the bend.
When mine was loose, it rested on the console, and only required minimal stretching.
As to the dash, we made the attempt twice, before you see the results above. The toughest part was the layout and getting it to rest correctly in a relaxed state so that it only took minimal stretching. The part that was actually the toughest was the driver's side between the cluster and the edge of the dash. The rest of the dash was a cake walk.
I don't know how you plan on finishing the console you have there, but my thought to mine would be to cut out a piece of ABS plastic to fit the shifter area. Wrap that in vinyl, and make it a tight fit, holding down the wrapped vinyl. The shifter bezel would attach to that piece, and should give the whole area a nicely finished appearance. I originally just tried laying a piece of vinyl in there and gluing it down, but I wasn't happy with the final appearance, that's when I came up with the idea of an extra piece that fits in there.
Official Rennlist
Borat Impersonator
Borat Impersonator
