alternator troubles
i have an 86 951. when i got it about a year ago, it had an autozone alternator on it. recently, that one died, so we put another one on it...and it died within two weeks. then i went to get another one, and they tested it in store and it worked, so when i put that one on(the 2nd one within a month) it died. is there anything on the car i should check? thanks guys
Have you changed the voltage regulator? It also never hurts to clean your grounds. Just be sure to plug the opening at the top of the bell housing. There is a ground at the back of the engine right over that, and if you drop the bolt into it, it will ruin your day. Good luck!
Alternators don't die. They get killed. Just curious but what voltage output where you reading. I'm betting on a bad voltage regulator.
these alternators come with a new vr.
whether autozone or whoever, if you get a bosch rebuilt unit, it's like the shops get too. anything other than a bosch rebuild is risky.
i got a bad one a while back, took it back and no further problems.
87951
87951
the battery is charged and good. it reads normal when it works, then it suddenly stops reading anything. that unit you have, is it a bosch? i don't see how it could kill 2 alternators within a month...maybe i just got unlucky?
