944S worth?
I recently went to see a black 87(if I remember correctly) 944S that had a lot of work put into it and then sat for about 2 years, I think about ~120k miles (I definately forget), new clutch and brakes, a few other things. Exterior looks great except diff color black door and missing "s" on back. Assuming I'm buying it in non-running condition (even if it does), what's it worth? It needs a hatch seal and balljoints to my knowledge, belts and pumps were done before it came off the road. I have no clue about S's. Thanks.
Captain Obvious
+1...check the cam tensioner pads and belts...you'll know if its an S if is a dual cam too.
should have "16 Ventiler" badges on mid fenders too, along with same on airbox.
The airbox is 16 ventiler, saw a different intake manifold and few other underhood parts I didn't recognize, didn't see but wasn't looking for badges on fenders, there was the outline of an s on the back too. I offered the guy 1500 (figured why not) but haven't heard back, gonna see him tomorrow. How do I check the cam tensioner items, under belt covers?
I'm real worried about that T belt that sat for 2 years, taking a set, drying out, stripping its teeth. And it's true you'll need to know the status of that chain tensioner - ~80K is about as long as as it should ever go I think, so if it's original it's pretty risky. Problem with checking that is you have to remove the valve cover, which is a piece of cake unless the bolts break - might be awkward if that happens before the deal closes.
New clutch, brakes, and water pump sure is nice. A well sorted S is a real pleasure, believe me. Might take several grand to get there, and you won't get much money back out of it (something like $5K max for those miles, I would guess). So don't think of it as an investment or anything.
And I guess you'll need to buy that little S that the PO probably kept as a trophy from automotion.com or somewhere (~$25).
depends on the car. Guy up the street bought his because the PO said the lifters were ticking and he didnt want to mess w/ it. I listened to it and predicted the end of the tensioner pad. Pulled the valve cover and the pad was gone- chain was riding on the tensioner piston! $400 for a tensioner plus a chain, pad, belts and rollers- runs great now. If the car is nice enough thats a killer price but i would check everything out before or after you buy it.
