Suspension Setup
#32
The way Sonny explained corner balancing to me was make an X with the four wheels. your are in the middle of the X.
if you adjust the height of one wheel, it affects the other side of the line in the X. when all four are at the same weight, you in the middle of the X are in the center of the mass.
so it isnt so much getting everything to be the same height, but getting every wheel to have the same weight as you toss it around.
#33
eee gads.... i've been watching this thread.... i have no objection to rolling up my sleaves, trashing my manicure and getting my hands greasy, but this is sounding way more complicated than i can do....i think i will bring mine into the shop and have a professional do it.... i'll stick to changing tires and wiper blades
but jeeper, you are definately my hero....
#34
#35
-Z
#36
Am I still your hero?
#37
oy veh! the way people will sell themselves just to get out of cone duty never ceases to amaze me.
To follow the theme here i should say:
jeeper you're so wonderful.
as in
Oh waldo you're so wonderful
Oh alfalfa you're my hero
no I am not following the theme. Someone has to expose him for what he is. King of cones or not.
Jeeper you bite!
And i am not working station 5 on the other side of the lot!
there, now i feel much better.
as in
Jeeper you bite!
#38
#39
as in
Jeeper you bite!
as in
Jeeper you bite!
#40
I dropped my rear suspension as far as it would go using the rear eccentric bolt adjustment, then used the helper spring/coilovers to push it up 1/2 inch. I probably ended up a tad under original height, but the coilovers are working in tandem with the t-bars. I'd be SOL if I wanted to significantly lower the car, but to avoid the horror of indexing the t-bars, it was well worth it.
