Why Does The Oil Pressure Gauge Bounce?
Old 02-26-2008, 12:31 AM
86_951_
86_951_'s Avatar
Default Why Does The Oil Pressure Gauge Bounce?
Mine bounces pretty good when it's warm and idling. Between 3 and 4.5 bar (I think). Is that normal?
Old 02-26-2008, 12:40 AM
Calmchaos
Calmchaos's Avatar
Mine wiggles when warm at idle between 2.5 and 3 bar with 10w40 in it.
Most wiggle I get is +- .5 bar at idle. I don't know if it's normal or not though.
Old 02-26-2008, 01:21 AM
FRporscheman
FRporscheman's Avatar
It's common but it "shouldn't" bounce. A system that is working properly would show a steady reading. If it wobbles, it could be an old sender unit or maybe gummed up OPRV / housing...?
Old 02-26-2008, 01:36 AM
Lizard944
Lizard944's Avatar
Mine does that too. A little twitch/spasm every other second or so. I'm going to have to write it off as "normal" in order to restabilize my blood pressure searching for answers. So far , replaced oil pressure sending unit, changed oil cooler seals, cleaned all grounds plus made new ground cables & installed auxiliary ground, cleaned all contact points on back of instrument cluster, tried variety of different weight oils over the years, to no avail. Been going on since I bought it 17 years ago.
Old 02-26-2008, 02:21 AM
Wipeout
Not Special
Wipeout's Avatar
Also does it here while at idle. 2-2.5 with 15w-40.
Old 02-26-2008, 02:59 AM
Keithr726
Keithr726's Avatar
Mine too, its the sending unit
Old 02-26-2008, 08:25 AM
tjbreen
tjbreen's Avatar
Mine has been doing this since I bought it in 2001. In 2005 I pulled the head and did the bottom end. Bolted everything together with a new Bosch sending unit, new seals on everything near the oil filter housing, oil pressure valve, etc. and it still bounced when warm. I run 20W-50. Last year I changed the sending unit again, to a non-Bosch part, still bounces.
I have cleaned every ground I can find, tested every sensor according to the writeup in Clark's, and still show 3/4 tank when full. It is one of those things. Someday I will retire and if I still own this car, that will get fixed.
Old 02-26-2008, 09:41 AM
asnowsquall
asnowsquall's Avatar
don't let it idle, its bad for it.
Old 02-26-2008, 10:49 AM
Rip It
Rip It's Avatar
Try adding oil to about a 1/2 qt. above the full line on the dip-stick. Mine stops bouncing when I due this.
Old 02-26-2008, 10:56 AM
bluedevil
bluedevil's Avatar
Mine bouces as well, had me scared recently since it has been a while since I have had my car on the road. I will check into that sender unit.
Old 02-26-2008, 11:17 AM
Rip It
Rip It's Avatar
My sender is brand new OEM, it bounces.
Old 02-26-2008, 12:29 PM
knfeparty
knfeparty's Avatar
Mine did this even after I replaced my sending unit. My guess is that the design of the sending unit isn't that good, or it's the usual electrical gremlins these cars have. But I imagine it's more of a gauge problem then an actual oil pressure problem and you shouldn't worry about it.
Remember, if it doesn't directly impede the car from rolling, it's not broken...
Old 02-26-2008, 12:38 PM
86_951_
86_951_'s Avatar
I had an 89 Eagle Talon that I drove into the ground. My motto was "If it does not directly affect it's ability to stop or go, it does not need to be fixed."
Needless to say I feel a little different about the 951.
Old 02-26-2008, 01:30 PM
schwank
Herr Unmöglich
schwank's Avatar
Mine did this even after I replaced my sending unit...
Same story here. Brand new sender, still get pressure gauge bounce when warm.
Old 02-26-2008, 01:56 PM
bearone
bearone's Avatar
over servicing leads to foam, which can as bad, if not worse, than running low on oil.
i get a little bounce at idle.
87951
Quick Reply: Why Does The Oil Pressure Gauge Bounce?
