Helicoil Vs Time-sert
Hi there,
Planning to replace my water pump I'm seriously thinking of getting hold of some kind of thread repair kit. Looking about the two main contenders seem to be helicoil and time-sert. The views on-line seem to be:
- Time-sert seem to be more popular but helicoils more widespread
- Time-sert seem to last much longer
- Time-sert may have a slight raise on the outside which rules them out for use when gaskets are involved (e.g. waterpump)
- Time-sert seem to be more expensive
So, what are people's views on this? Time-sert, helicoil or one of the other contenders (recoil, rethread etc.).
Thanks!
Alex
Thanks!
Alex
timesert- although a couple of the studs go directly into the coolant passage at the front of the motor- which is what i encountered- and you will have to seal the timesert threads before you install them, as well as the threads on that bolt. I had one that stuck out and just ground it down smooth w/ the block- alittle rtv on the wp gasket doesnt hurt anyways.
Time-sert can take more torque. And there shouldnt be a raised edge with a timesert if you do it properly, you are supposed to countersink the edges to avoid a lip.
Mark
Mark
I'd check here Helicoil vs Time-sert for a wide range of details on application positives and negatives.
I typically don't get too concerned with thread repair kits until there is a problem. As long as you are careful you shouldn't have any issues but having a kit on hand, especially if you don't have a second vehicle and a good parts store nearby, is probably an idea I should consider for bigger jobs.
helicoils worked great for me. I replaced all water pump threads with helicoils as they were all pretty much stripped when I removed the rusted bolts.
the water pump bolts are not high torque so I think helicoils work great but for other things I guess the timserts would be safer.
I don't see anything wrong with helicoils.
yeah the one was awful close to the head stud and i didnt want to get into the side of it so i ventured close as i felt comfortable and then just installed the timesert and ground the end of it off. The other was countersunk.
Mark
Great, thanks for all the tips!
I haven't actually stripped anything yet but judging from other people and from the state most of my bolts are in I suspect I may have trouble.
Over in the UK it seems very difficult to get hold of time-serts so I'm probably looking at helicoils or equivalent. Helicoils are also hard to get hold of and I was wondering whether "rethread" which are in better supply can be considered?
Thanks!
Alex
Thanks!
Alex
