944 Automatic
Old 01-27-2008, 06:45 PM
rennsource
6th Gear
rennsource's Avatar
Default 944 Automatic
What are the pro/cons of the 944 automatic? 1987 is the year I am looking at. Who made it? How often does it break? Car has 142K on it. Hold off on all the 'what a wuss i am' comments, like the other 944 automatic poster, i'm getting for the wife who will never drive stick.
Old 01-27-2008, 06:56 PM
John_AZ
Proprietoristicly Refined
John_AZ's Avatar
Check to make sure the automatic transmission flex damper has been checked or replaced. Looking up prices, the part alone costs $1000+- and then labor. The rest of maintenence is basic 944. Have a PPI done.
Here is a link to a similar Q. http://forums.pelicanparts.com/showt...25#post3719725
Good Luck
John_AZ
Old 01-27-2008, 09:23 PM
Mamooguy
Mamooguy's Avatar
What exactly is the flux damper plate? Where is it and what does it do?
Old 01-27-2008, 10:21 PM
FRporscheman
FRporscheman's Avatar
It goes where the clutch goes on a manual car. It's like the rubber center of a clutch. It softens the torque of the engine going to the transmission.
It's possible to run a flywheel, pressure plate, clutch setup instead of a damper plate. It would do the same job, and the parts are only like $500. You can also install the master/slave cylinders and a pedal, and make it an auto car with a 3rd working pedal .
Old 01-27-2008, 10:25 PM
Mamooguy
Mamooguy's Avatar
So it's part of the tranny then. But I had a tranny swap on my '87 AT and it only cost me about $500, replacement tranny included.
Anyway, good to know. I think mine's starting to go. Dammit.
Old 01-27-2008, 10:41 PM
Legoland951
Legoland951's Avatar
Its not part of the tranny. The torque converter is by the tranny but the flex damper is by the engine. You can use a VERY USED spring center clutch assembly as it never has to disengage in place of that damper and the part will cost you nothing but you will have to have a flywheel, pressure plate, and spring centered clutch. There will be more vibration but it will last forever. The auto tranny has no overdrive so it will take the engine to rev a lot at highway speeds and its not very fuel efficient.
Old 01-27-2008, 11:32 PM
Mamooguy
Mamooguy's Avatar
Anyone know what the symptoms are of a bad flex plate? Something in my drivetrain is acting wonky. It runs fine at city speeds, but once the speed and rpms kick up, I start to hear a rubbing whine-type noise, which stops as soon as I take my foot off the gas.
I've assumed it was something with the tranny, but this flex plate deal ...?
Old 01-28-2008, 01:03 AM
brianh
brianh's Avatar
I sold my '89 NA auto with just about 200K miles a couple of years back. I had to replace the damper plate at 80K miles then $160K miles - like clockwork. As I recall a couple of K$ each time. When it gives out it won't leave you stranded. There's a fail-safe that will keep the drive train engaged - but it makes a hell of a disconcerting clanking sound.
Old 01-28-2008, 01:11 AM
Legoland951
There is a failsafe until the weld breaks off the tab. Then you have a completely disabled car. I bought one like that for my wife and converted it to manual.
Old 01-28-2008, 12:23 PM
Mamooguy
Mamooguy's Avatar
Thanks for the tip. Doesn't sound like that's what the problem is.
Actually I'm pretty sure I know what the problem is: I destroyed my tranny a couple of months ago while replacing the insulating foam beneath the shifter. I bent the cable mount slightly in the process, screwing up the gear selector. Heard a horrible grinding noise until I straightened it out, but it hasn't been the same since. Ring and pinion, I'm thinking.
I'm such an idiot, it was a lovely transmission (and only a couple of month in the damn car)!
Quick Reply: 944 Automatic
