Leather dash attempt..
I'm prayin' to the P-car gods for you :-) Especially as my dash is cracked and would look nice in leather... Want to see how you go first!
I emailed the fella at the 928 leather shop about their dash covers - apparently it requires a lot of carefull fitting, and a "custom bracket" below the dash to hold the back edge of the cover, plus they insert a trim piece into the vent on top to cover the edges of the leather too...
I'd you'll need to do a lot of careful measurements - and get really inventive around the vents and the glove box...
Good luck man!
Good luck man!
Good luck man!
Good luck man!
Thanks.
Almost Addicted
The old saying is measure twice, cut once- measure 10x, make sure your measurements are correct, make sure what you think the measurements should be is actually correct, measure a few more times.... then cut. And don't forget the supreme rule: post pics.
Well, i've tooken off all the old vinyl, but should I start recovering now? The leather dosn't show the cracks, it just covers them up. BUt if I did that would the dash be uneven?
![](http://i165.photobucket.com/albums/u42/Po924S/IMG_3555.jpg)
Almost Addicted
