Wanna see my old clutch?
I just got my car out of the shop today. When they showed me that I just had to get a picture! I can't believe I was driving around with that thing.
Although now that I've got my car back, it feels different. The grinding during shifts is gone, and so it the rattle at 3k rpm. However I've noticed some stuff.
1) My car doesn't seem to pull as hard as it used to. Not that it was a monster, but it just feels like it's lost just a little.
2) It almost sounds like there's a hole somewhere in my car, cause during acceleration I hear a lot more from the transmission than I used to.
3) No matter what setting I put it on, I only get hot air. Like HOT hot air, like I had the heater up as high as it would go.
1 and 2 I'm willing to chalk up to new parts, but 3 is just weird. I suppose I'll call the shop Monday, see if they know whats up.
2) I myself have no personal experience with replaced clutches (mine is original), but I have to ask, did you replace the clutch with one that was not rubber centered? I'd think it would seem reasonable that a metal centered clutch would transmit more vibs through the car.
3)I have had the same problem... Have you checked the "heater clips" that connect the vacuum actuators to the flaps that control whether you get heat or not?
Well I think I may be able to help you with #'s 2 & 3.
That clutch rubber looks horribly familiar. I put in a Sachs spring clutch and its just as smooth, ebeit without the slack in the driveline.
I had a little trouble driving as smoothly with this spring clutch. My car just felt a tad different, and while I didn't get any of the big jerks I used to, I still most times got a little jerk.
It is a spring centered clutch, which I expected to be a little louder. It's nothing horrible it's just much more noticeable. And as for the heater clips, no I haven't. It was dusk when I picked my car up, but I'll check tomorrow. Anyone have pictures of what exactly I'm supposed to be looking for?
http://www.clarks-garage.com/shop-manual/hvac-01.htm
I just had the clutch on my 87 44S replaced with the sachs spring centered clutch. Although there is a bit more vibration at idle, there is no more rattle. the car feels more responsive and feels like a new 21 year old car. pic of the clutch attached.
What year is your car??
The heater clips are only on late cars. On early cars with heat issues the problem is usually the cable that goes from the dash to the heater control valve. Sometimes the cable comes loose from the valve, so moving the lever (which moves the cable) will have no effect. The HCV is located just above the clutch housing, so it stands to reason that during the clutch job, the mechanic knocked into the HCV and knocked the cable off.
Also, the extra sounds you're hearing... are they coming from the shifter area? During the clutch job, the shifter lever must be removed... and in that area is a big foam blob. Maybe the mechanic took out the foam and forgot to put it back in. If you pull up your shift boot, you should easily see the foam (or not, if it's missing).
Good luck!
Good luck!
It's an 88. I was just out there looking for that clip as per ClarkGarage, but if it's there I sure as hell can't find. As for the tranny noise, it almost sounds like it's coming from behind my seat. I'll check for the foam though. I guess I'll just have to take it back to the Shop to get the heater fixed.
Even on late cars, with a vacuum HCV instead of a cable, the mechanic could still have left the vacuum line to the HCV disconnected, and this would always give heat. Just another thing to check for.
The HCV is in the back of the engine bay, between the firewall and engine. You can see it from the driver's side looking down behind the oil fill neck.
