Fuse Keeps Blowing
Old 12-30-2007, 07:00 PM
Will Feather
Will Feather's Avatar
Default Fuse Keeps Blowing
I did a search on the topic and didnt really find anything too useful, just a few people with other fuses blowing. My #12 fuse keeps blowing. It as an 8 amp and it controls the guage lights, ashtray light, glovebox light, and liscense plate lights. For hours today I went through all the liscense plate light wires and they are fine, I also cleaned a ground in the back. I took out my glove box light and checked the wires, I also cleaned a ground behind the glove box. I havnt taken the dash apart yet, but is the ashtray light the light on the headliner? I ask this because the light on the headliner works even without a fuse in the number 12 position at all? Any other suggestions, or am I missing something obvious?
My car is an 84' 944.
Old 12-30-2007, 07:20 PM
UncleMaz
UncleMaz's Avatar
Of course, with all wiring gremlins, it is a guess and each case is different: The culprit for much of my dash problems was the hot wire on the turn signal/wiper assembly - the one that ignites the high beams when you pull the turn signal back partially (brights flasher). It connects to the dash pods via the indicator lights. Hope you find it soon, wiring problems are the devil.
Old 12-30-2007, 07:51 PM
marky522
marky522's Avatar
What do you have plugged into the cig lighter? Any aftermarket stereo/electronics? How long does it take to blow a fuse?
Mark
Old 12-30-2007, 07:58 PM
Will Feather
The fuse blows immediatly, this problem started last night. Last night it took maybe 5 mins for the fuse to blow, now it is instantaneously. Nothing is plugged into the cig lighter. I thought it may have been my radio but I pulled the radio and it still blows the fuse immediatly.
Old 12-30-2007, 08:01 PM
yellowline
Under the Radar
yellowline's Avatar
Check the overhead light. I had a similar problem. The $8 dome light broke inside and was shorting the circuit to the body. That would instantly trip a fuse.
Try that before you pull half the dash apart like I did.
Old 12-30-2007, 08:08 PM
Will Feather
Ya, I just remebered that my dome light is working, even with the fuse out. Its the wierdest thing...
Old 12-30-2007, 08:10 PM
Todd157k
Todd157k's Avatar
Is it a direct short or over current? Check with a meter. A direct short will be 0 ohm to ground. Over current (or partial short) will be a resistance. You're going to get some resistance simply because of the light bulbs.
Best way to track down an over current is to start pulling light bulbs. After each one, check the line to see the short (with a meter).
Old 12-30-2007, 08:13 PM
yellowline
Under the Radar
yellowline's Avatar
There's a metal tab holding it in- pull the tab inward (towards the clear plastic), and pull down.
Old 12-30-2007, 08:21 PM
JayVee
JayVee's Avatar
Check out these wiring diagrams in Volume 4:
http://www.cannell.co.uk/Manuals.htm
Once you find out what's on the circuit for the fuse that's blowing you can start to isolate the problem (short) by disconnecting circuit loads (bulbs). The 12V wire for the gauge lights goes through the dimmer pot on the dash. I'd disconnect the dimmer pot to see if the fuse survives. Also disconnect the lighter using the procedure to remove the clock as shown on Clark's garage. Removing the license plate bulbs is also worth a try.
Old 12-30-2007, 08:26 PM
Will Feather
Dimmer Port? I have 2 different light switches and I tried both, but how do you disconect the dimmer port?
Old 12-30-2007, 08:27 PM
yellowline
Under the Radar
yellowline's Avatar
Never mind- interior lights are fuse 7.
At this point, your best bet is to pull the negative cable off the battery and check the circuit with a multimeter.
Old 12-30-2007, 08:55 PM
JayVee
JayVee's Avatar
I meant dimmer pot (as in potentiometer). On later cars there's a brightness adjustment wheel for the gauge lights. Does your car have a way to adjust the gauge light brightness? If so, this would be the thing to disconnect.
Old 12-30-2007, 11:34 PM
marky522
marky522's Avatar
A real easy way to diagnose this is ( it sounds like a dead short) take a test light and put it in place of the fuse. the light will light up because one side is power and the other is a dead short. Start messing with connections, wires ETC till the light goes off, and you have found your short.
HTH
Mark
Old 12-31-2007, 01:22 AM
Will Feather
JayVee, ya sorry about that, yes the early cars do have a dimmer but you cannot disconect just that as the light switch and dimmer is the same connector. Thanks for the replies guys, I guess I will just have to work on this. God I hate electrical problems, they are truely the worst...
Old 12-31-2007, 11:57 AM
JayVee
JayVee's Avatar
Here's some more info that may help. Pages 66 and 69 of Volume 4 show the circuit for fuse #12. At the top of page 66, fuse #12 is shown feeding two branches, one that goes to F13 and one that goes to G4. If you could disconnect one of these branches right under the fuse box then you could isolate the problem to either the connection to the license plate lights or the connection to the interior lights. Does anyone know if these connections from fuse #12 to F13 and G4 are just wires under the fuse box?
Quick Reply: Fuse Keeps Blowing
