Offset help please
Offset help please
A friend of mine has asked me if I'd like to purchase a set of 17" wheels from his boxster as he just changed to 18's - I beleive they are 3-piece. The fronts are 7.5" wide with an offset of 40mm & the rears are 9.0" wide with an offset of 39mm.
I have a 88 951 - would I need to use spacers? If yes, any idea what size??
Any help would be appreciated.
I did search, thank you - but the results are all over the place and mostly focus on the difference between early offset & late offset cars.
So, does the 12mm difference between my offset (52mm) and the wheels I'm considering (40mm) mean I need a 12mm spacer, or that they will stick out of the fenders???
Nissan Rulez
Hope that makes sense.
Unfortunatly with your late offset 951, those wheels will probibly not fit correctly, they will just stickout to far. Thats not saying they wont work, it will be a very aggressive fit, but you will need to mount the wheels to be shure.
Hope this helps,
-Dan
Nissan Rulez
Besides sticking out beyond the fenders, what are the other risks involved with using wheels with the wrong offset? I would imagine that it could create issues with the studs snapping/shearing, or no?
Nissan Rulez
using spacers and adapters should not be taken lightly. I recomend the slipon style spacers and longer studs. I used to get all my studs from paragon products. BBS, H&R, and other reputable companies make nice spacers.
You will want to make shure your suspension, bushing, wheelbearings, well really everything, is in good shape too. larger wheels and lower offsets create more stress on these parts than the stock wheels.
Lastly, I have never heard of any studs that were good quality and installed properly, shearing off.
-Dan
