I need water pump
UAE Rennlist Ambassador
Talk to Kirk, he knows what you need, and don't forget to order new hardware.
You might want to consider doing a kit like I did.Check it out.
http://www.944online.com/cgi-bin/ASI...ercooling-9441
Welcome to Rennlist... you'll find everything here.
Including a pic of how you can tell the updated water pump in your car (you'll have to remove the timing belt cover). The updated water pump has a bar to separate the timing and balance belts, and two bolts to hold the bar - click for a pic
WOW...found one at zims for 85.00 thank you, remanufactured of course
