Does anyone have an extra oil breather hose?
Part number 644 107 187 02 for a late 87 944. Everyone seems to be out of stock on this.
Please PM me if you have one available!
Edit:
Surely someone else has needed this! Any advice as to where I might find one? None are available from Porsche in the US or Germany. Does anyone make an after market version or is this something that can be made with standard hose and fittings?
Given the labor required to install this I am reluctant to buy a used one, but that may be my only option if my current hose continues to split. (It's held together with a brass fitting and hose clamps.) When buying a used one is there anything to check for other than what I would consider obvious, such as looking to see if it is cracked or dried out?
Thanks!
Edit:
Thanks!
Note part 46. It's like a relief valve in case there is pressure instead of vacuum. On the 968, which also came equipped with part 46 and a breather hose to accommodate 46, the breather hose was superceded with a new part which has no provision for that valve. I guess they figured it's not necessary. The new hose is just a plain hose with some bends. It cost only $20 or something.
But I don't know what that second tee is for (by part 48). Perhaps you can't find the factory hose because it was superceded by a new part number. If you give up you can use a straight hose from kragen like I did. But the new 968 breather hose is straight anyway so that might not work for you.
