Anyone ever have a leak like this?
Old 11-09-2007, 01:55 AM
Buckaroo Banzi
Buckaroo Banzi's Avatar
Default Anyone ever have a leak like this?
Removed the Power steering bracket looking for a leak found nothing.
Don't see anything comming from the oil pump or oil filter housing.
Any suggestions I am stumped?
TIA
-BB
Old 11-09-2007, 02:20 AM
35thSLP
35thSLP's Avatar
Again, Check your oil cooler housing...
Old 11-09-2007, 06:40 AM
billthe3
billthe3's Avatar
Damn thats a clean engine.
Check the cam housing area as well, since that is above the power steering pump.
Old 11-09-2007, 07:21 AM
Legoland951
Legoland951's Avatar
That appears to be the lower balance shaft O ring or seal. Change that first and see if its coming from above that.
Old 11-09-2007, 08:44 AM
xsboost90
xsboost90's Avatar
mine was doing that and it was that small crappy seal on the front of the cam housing leaking behind the belt covers and dripping onto the balance shaft. Took awhile to find it but now that i fixed it she's dry.
Old 11-09-2007, 09:04 AM
tomrc
tomrc's Avatar
+1 for cam or balance shaft seal. Best do a front engine seal, replace all at once. Ask me how I know.
Old 11-09-2007, 10:06 AM
Yabo
Yabo's Avatar
are you sure its not antifreeze? if it was, check the top portion of the lower rad hose.
Old 11-09-2007, 12:51 PM
knfeparty
knfeparty's Avatar
I think you would probably die on the spot if you saw a similar picture of what my engine looks like from that angle.
I left a small pool of oil in my sister's garage once. This is even with new oil cooler seals and front engine seals.
Old 11-09-2007, 01:15 PM
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
yup definitely front lower balance shaft...
Old 11-09-2007, 08:10 PM
aribop
aribop's Avatar
Invest the extra money and replace all 3 of the metal sleeves when doing a front engine re-seal. (both balance shafts and camshaft) Depending on how many miles are on the engine, also replace the oil pump drive gear. All of these items will eventually develop a groove from rubbing on the seals. If you only replace the seals and still have leaks, check the condition of these sleeves.
Old 11-09-2007, 08:49 PM
PorscheDoc
PorscheDoc's Avatar
Is it oil? It looks like a drip of coolant from the picture. That is some really clean oil if it is
Old 11-09-2007, 08:50 PM
KLR
KLR's Avatar
I'd vote for front balance shaft seal from that housing as well. Two other options are the oil pressure sender (unlikely, but you might get lucky) or it could be a bit of left over oil that you missed last time you removed the filter (no one's ever that lucky).
Old 11-10-2007, 02:17 PM
Buckaroo Banzi
Default Check Again..
Well I followed your suggestions and checked the cam box gasket and the oil filter housing and every square inch of the block with no luck.
I dismissed the lower BS seal suggestions at first because the seal is new. I am re-thinking that because the only leak I could find is around the balance shaft. So I think I will pull it again replace the rubber gasket again and this time SEAL the housing with Yama Bond and see what happens.
Any fault with this plan?
I want to thank all who have responded. I was very surprised to find the WATER COOLED Forum much more responsive than the 944 Turbo Forum.
I wonder why that is? Not enough drama in an oil leak I guess???
thanks again,
-BB
Old 11-10-2007, 03:00 PM
Calmchaos
Calmchaos's Avatar
Please let me know what solves this for you. I have the exact same leak!
Thanks!
Old 11-10-2007, 03:09 PM
Wallace
Wallace's Avatar
If the lower BS seal is new and still leaking, you may have to replace the sleeve on the balance shaft, just like aribop said.
Over time the seal wears a groove in the sleeve, and even when you put a new seal in, the groove is still there, and oil leaks.
When you change the seal, check the condition of the sleeve. If there is a groove that is deep enough to catch your fingernail on, then it needs replacing.
Another possibilty, i dont think anyone mentioned, is the mylar washers at the balance shafts. Were these replaced and installed correctly?
Alot of people forget these. I know I did, and I had a simular leak as you.
Quick Reply: Anyone ever have a leak like this?
