used fan - a small problem
I finally got the radiator fan. It's a used one, but appears in good shape, except the first couple of times I applied voltage, it didn't spin. After that it works fine.
Can I assume it will work just fine? or I should open it an use fine sand paper to polish the electrical contact surfaces? But I worry that it's difficult to put it back together. What do you guys think?
If its been sitting not used for a while, it might have just needed a tap to get things going.
Id run it personally.
Ive had plenty of **** in my life that just needed a tap and would last for a long time. Just like my ex gf!
sounds like most of you guys think I should use it. There actually is a tiny hole in the housing. Maybe it's for spraying contact cleaner inside?
In any case I'll keep testing for the next few days before I install it.
