Motor Mounts...DONE..My what a difference
Got the passenger side in after playing tug-a-war with the crossmember, but now I'm stuck! Where do I need to pry to get the driver's side out. There's lots of room to negotiate it out, but I can't find a good pry point, there always seems to be something else important in the way (brake master cyl., wiring).
So for those of you in the know. Where do I pry to get the driver side mount out?
How loose do you have the cross-member?? When I recently did mine, I essentially backed the cross-member bolts all the way out, then put them back in only a full rotation or two. Lowered the pass side the same amount to get clearance, but the real bizzatch was trying to get the new one in!
I have the cross member held in place by about two threads on each of the four bolts, but there isn't enough clearance. If I pry between the motor and the cross member I can make enough room to get the pass. side out, but can't get the driver side. I need to pry on something but can't find a spot to get good leverage to provide the clearance I need.
hey bill- my phone never rang but i got your voice mail- didnt even show up on the missed call screen. huh. I have no clue as ive never changed them in the car before. Can you chalk up the motor and drop the crossmember down some more?
I'm not sure if there's something I need to detach that I didn't, but I have the engine supported from underneath and the cross member by two threads on each bolt. I've tried jacking the motor up some more and the cross member wants to follow it up.
I don't know how correct of a method this is, but when I was reconnecting my steering rack I lifted up the engine with a jack and piece of wood on the oil pan and was able to lift the engine and driver side mount bracket piece completely off of the motor mount. Had I been changing the mounts it seems like it would have just been an issue of pulling the old one out and sticking in a new one.
Good luck,
Riff, thats what I was thinking but when I pryed a little bit the whole mount would go loose, but without giving enough remove to remove it even with all the bolts disconnected. Got it done this afternoon, but no where near the method described in Clarks Garage. What ended up having to happen was that I pulled the "foot" on the driver side and removed it so that I could get to the mount. Took about two mins then to get the old mount out and the new in.
Drove the car about 30 miles last night. Holy crap did that make a difference. It now feels like my car just got 10 yrs younger. It starts much smoother and pulls smoothly up to redline. I'm amazed at the difference $240 and 8 hrs of work made even if it was a PITA to do. That said I don't think I'll ever want to do it again.
--feeling a little nostalgic, so I'll point you to the legendary SoCal Driver to answer that one (sure miss him).
post #7 here:
http://forums.pelicanparts.com/showt...t=cross+member
New mounts surpised me too. Thought my car was stalling at first since I could barely tell it was idleing.
post #7 here:
On the Radar
