A few questions from a new 951 owner
I have a few questions.
1. There are a few rattles. I know the car is 21 years old, but are there certin things in the car that work their way loose that I can tighten up?
2. The headlights aren't that bright. I saw a kit on 944online. Do I need to upgrade the wiring harness?
3. I also saw on 944online a headlight relay that is attached to the headlight motor? Are those the same for all model years?
Thanks,
Chris
Thanks,
Chris
Cast Iron Man
Welcome to Rennlist Chris!
Yes, rattles are common in a 20+ Porsche. It's just a matter of systematically tracking them down. I had a broken wastegate bracket and a heat shield that cracked into 3 pieces. Took me a while to get that straightened out.
Call Travis at RennBay about his lighting kit. You don't need a new harness with his kit. It's a big improvement over stock lighting.
http://www.rennbay.com/
AFAIK the the headlight relays are the same. Travis can probably explain it in better detail than my self.
i would clean up the grounds and think about some h4 lenses. Look and work much better than stock. Hatch usually rattles- pins need tightened slightly. Dash will creak when it gets cold- sometimes alittle lithium grease helps...sometimes.
I've heard great things about Rennbay harnesses. But you don't really need them if you stay with the stock wattage lights. I just upgraded to Hella H4 euros, which are far brighter than the stock sealed lamps. It's a quick, easy upgrade that takes under 10 minutes.
I guess I'm lucky, haven't noticed any rattles or creaks. My knees make more noise than my car :-)
