REAL HP IN 944NA
#62
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
I don't know waht you guys are talking about my car dyno 172 hp at rw, I can probe it finally I guess found how to resize using infraview my problem was after resized there is a scream saying keep same qaulity and Just hit 10% yes my car isnot perfect need a paint job, but is 21years old anyway my upgrades for those how belive are
2.5l webcam(racing 251 lift for racing use)
new balace flywheeel fom fidanza
light weight pulleys lindsey racing
a/c deleted
p/s deleted
SCvison maf set up
promax racing ecu chip
headers
original cat
BB cat back
adjsutable fpr
running 45psi fule 98oct
4*electrodes platinum plugs
k/n air filter stock box
I got 170-172hp atrw
-I have 6l msds will be installing and will increase fp to 55psi
I hope get 175-178 hprw !!!will see
a/c deleted
p/s deleted
SCvison maf set up
headers
original cat
BB cat back
adjsutable fpr
This guy is talking out of his ***. Increasing fuel pressure just because of a spark increase will yield aboslutely NO GAIN. YOu increase fuel pressure to suppress a lean mixture. On an NA, increasing fuel pressure to 3-bar and beyond without forced induction, or a high-lift cam and compression higher than 11:1 is asking for fouled plugs every 3,000 miles.
Platinum plugs are by far also THE WORST PLUGS YOU CAN EVER USE IN A 944. Platinum has less conductivity than copper so how can it help increase power? 6L MSDs.....do I really see another S after that msds'? Surely you gest.
Lightweight pulleys also have NEVER BEEN PROVEN TO GAIN POWER ON 944s. Not now, not ever...especially with those modifications.
This guy would even make ricers sick... Paul Walker and Vin Diesel I bet give him the finger and tell him to go NAWWS himself
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
#64
Fuse 24 Assassin
Fuse 24 Assassin
Neither do copper plugs, nor silver...
What do you mean corrode? Plugs oxodize due to the heat cycles within cylinder and combustion, but not corrode. Corrosion would be similar to rust where something would cause the electrode to slowly break apart along with chemically destroy the properties of the metal....i.e rust.
#65
SEE MONGO i GUESS YOU ARE REAL MONGOLIAN!!listen I honest post waht I have and i have dyno just let me find out how to probe it to you !!even I have video!!your pronlem is like most of peoplr with 944 is dosn;t have the cas to but something better or sapend real dollares in your cart , but thansk god I do!! and also have plenty cash to spend in dyno machine at $ 150.00 each time , so you because in you imagination you think is not possible dosen't mean reallty is it !!!! so i post these treat to teach you and you friend a lesson with money and time everything is possible I can make a 944 200hp if I want but dosen't make sence for me spend 20k in upgrade motec, bigger bore and pistons, and light evrything if I don't race the car I just used the 944 on weekend every 3 months!!! the truth is nobody in all renlist has ever probe more thans 130hp in 944 why !!they don't have money to invest and they just skip and buy 951!!!
#66
Fuse 24 Assassin
Fuse 24 Assassin
You must be offended or embarrassed...your typing just went from bad to worse and your imagination has gone from deluded to inexistant.
Invest? AHAHAHAHAHAH! OMG that is some funny crap! Investment in a 944! That's like buying IMclone stock before they got busted!
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#67
sir with all your respect I can write perfect !! you question is why I use all weird writing?? simple to make treat more interesting, funny and get you guys attention!!anyhow I'll post back when I can find best way to download video, and after I do a run with the msd system and 55psi fp to see if really will increase something or not But to be honest I don't think something else can be increase !!! after my amazing hp numbers.Is that right? thanks anyway for time !!!!!
#68
Andy, don't even bother. This guy is just an instigator. Trying to explain how its impossible to achieve the hp he is claiming with the mods he has is like trying to explain electron orbitals or quantum theory to an infant. This guy obviously has never reached the Freudian maturation stage. Heck, he is probably still stuck on the oral stage. In the end, who gives a $hit what he obtained hp wise? As he mentioned in the last post, he just wants attention because he was probably an abused kid looking for approval that he never got. Too bad this guy is more annoying than entertaining.
#70
Hey let's keep an open point of view here. Its good to be skeptical but you really need to keep your mind open.
Dont you guys know **** about quantum physics? Ok, so maybe he looked at the dyno computer, seriously believed that it pulled 175 or w/ever, and the quarks jumped into place and the car mysteriously pulled 175. Who knows, in one universe it could pull 6000. However, as everyone on the forum has PAINFULLY pointed out, that's a highly improbable possiblity.
Its no use praying Chris, this guy can manipulate the theory so well he appears on forums randomly all the time. Flash fowards..flash backs...even some flash sideways action going on.
#73
Pjplurges, I think he has his tachions mixed up with his quarks. Instead of multiplying wavelength and Plank's constant to get MCsquared, he applied the asstro-glide lube mentioned by V2 to the point singularity aka black hole instead.
#74
Location: San Francisco, CA Porsche: '92 968 Blk/Cashmere
#75
Not Special
