Boxster Wheels on front of 944. No fit w/ bearing caps?
Anyone else have boxster wheels on their 944? I just put them on at lunch and the fronts won't seat with the bearing dust caps on. I left the cap off for now to put them on.. but has anyone else had this problem? How did you get around it?
oh, it's these wheels...
\![](http://www.photohost.org/gallery/data/500/2076img007-med.jpg)
You like my turbo bumper???
I know most people put them on the front of the car, but then I can't see it.
Yep, that is a problem with the newer boxter and 996 wheels. You can run thin spacers on the front to avoid interference between the wheel and bearing cap.
7 mm spacers are what is normally required if you use the OEM concave centers.
yeah ive had to run 7mm front spacers before- they actually dont stick out like you would think since the offset is slightly more in the front to begin with.
