Speedometer and odometer not working
The speedometer and odometer stopped working on my '93 Cab. I have had the instrument gears replaced. Does anyone know how to test an ABS sensor using a multi-meter?
Yes, the gears were recently replaced. Put the cluster back in the car and still nothing.
I pulled each sensor and checked them with an OHM meter. They registered from 1038 to 1069 OHMs. I don't know if ""OHMing" will give an indication as to whether they are good or not.
