Pressurized gas tank!
Old 09-04-2007, 10:49 AM
bader$
bader$'s Avatar
Have you removed your Charcoal canister (under the left fender) and plugged the lines? If not you have a plugged line somewhere to that canister. This is to store gas fumes when setting and then the engin burns them off when you are driving. There should never be pressure in the tank.
Old 09-04-2007, 05:30 PM
PeteL
Got Nothin'
PeteL's Avatar
My car used to whoosh when I opened the gas cap. Doesn't do it anymore.
So the normal condition is "no whoosh?"
Old 09-04-2007, 05:37 PM
bader$
bader$'s Avatar
Yes.
Old 09-04-2007, 08:41 PM
porscheEH!
porscheEH!'s Avatar
very helpfull!
Old 09-04-2007, 11:53 PM
CO951
CO951's Avatar
I have this problem when I track my car. I've had it make the wooshing sound for 30-60 seconds. Why would it only happen when the car gets really hot?
Old 09-05-2007, 06:20 PM
bader$
bader$'s Avatar
You have probably removed the canister and plugged the lines on your track car. You need to see if you can find a vented cap to go on it or put the canister back on.
Old 09-05-2007, 08:35 PM
Tenacious_G
Tenacious_G's Avatar
My girlfriend's honda makes a "whoosh" when you run the gas tank down. My 944 does too, I just assumed it was a common thing? Guess not?
Old 09-05-2007, 09:08 PM
porscheEH!
porscheEH!'s Avatar
I'll have to check those vcuum lines, does anyone know where the charcoal Line runs back to the tank? and is it possible to have the actual canister plug? And why would someone have dissconnected it?
Old 09-06-2007, 12:09 AM
Rock
Lazer Beam Shooter
Rock's Avatar
Its the gas tank... passing gas!
OHHOHOIHOHOHOHO
Old 09-06-2007, 08:46 PM
CO951
CO951's Avatar
MY car still has the canister, unless the PO removed it. It is not a dedicated track car, so I'm sure the canister is probably there. I've tried a slightly loose fuel cap, and I had problems with fuel coming out around tight turns, but it still had the wooshing sound when I removed the cap.
Quick Reply: Pressurized gas tank!
