Its alive!
Originally Posted by Crunky
Stormchaser, does it whine as much when you are on the throttle? Or only if you let off the gas in gear? I just noticed today that mine only whines when I let it coast in gear, but if I give it gas it stops.
It's not a particularly unpleasant sound, IMO, which is why I only recently became concerned. It doesn't sound like metal being chewed up. It sorta sounds like a swarm of honey bees, only metallic. Or, perhaps like a jet engine being fired up before ignition.
Stormchaser, you have deleted the factory crankcase vacuum system (or LR has). This is going to cause your turbo seals to fail pre-maturely. Search the Turbo boards for the fix.
