Clear Lens Introductory Specials from Hooked On Cars
Cottage Industry Sponsor
First of all let me thank those of you who hung tight until I was able to get the clear lenses in. It took a lot longer than anticipated, due to a few unforseeable events. Again, thanks for those who waited - I really appreciate that! And I'm convinced you will find the lenses well worth the wait.
Now that all clear lenses are available, I thought I'd give you guys two special opportunities to save a few Dollars:
1. The first 10 orders for 951 / 944 S2 turn signal lenses will receive a free new pair of seals, which is usually $9.98. Just add the seals to your shopping cart, along with the 951 turn signal lenses, and enter promotion code "RENNSEAL" at check-out. The promo will disable after 10 uses.
2. For those who want to convert all four side markers to clear lenses, I have a $199.98 package with four lenses and four housings. Make sure you specify the desired color of the housings (white or black) in the Special Instructions on checkout. No promotion code necessary for this offer.
Click here to see all clear lens offerings for the 944 and 951 models!
Addic
yeah, i like it, but im gonna have to wait a little while for after the 944fest. they look awesome, and its nice that someone came through and got all of them available
What color are the stock side indicator housings? Does the white or black plastic cause a difference in the appearance of the lense once it is on the car?
(Once I figure that out I'm ordering
Hi Bill: The stock side marker housings are white.
You could cut-off the amber lens, and use it with my clear side marker lenses. It's mainly a matter of whether you want to keep your existing markers, or spend the time and materials to cut them up.
Update:
I added one more "package offer" to the store: You can now order a set of all four side marker lenses without the housings for a slightly reduced price.
This is for those of you who don't plan to go back to the colored markers, and don't mind the extra work of removing your existing amber and red lenses from their housings.
Enjoy!!!
Same link as above...
Enjoy!!!
