How do you check and adjust engine timing?
Old 07-17-2007, 09:39 PM
tk's944
tk's944's Avatar
Default How do you check and adjust engine timing?
Old 07-17-2007, 09:47 PM
sweet9fortyfour
sweet9fortyfour's Avatar
If you're talking about ignition timing you can't adjust without something like Maxtune.
Old 07-17-2007, 10:08 PM
Mike C.
Mike C.'s Avatar
You really don't adjust it as far as a stock car goes. The DME has it all programmed in. Timing is constantly adjusted by the DME depending on rpm, air flow, ambient temperature, etc. That's what all the sensors are for.
Old 07-17-2007, 11:02 PM
sweet9fortyfour
The stock timing curves are ****ty they retard way too much. It retards to 24 degrees at full throttle(80% and up) regardless of rpms when you stomp it and stays 24 till rev limiter.
Old 07-18-2007, 12:18 AM
tk's944
tk's944's Avatar
That’s what makes me think my car has a chip. My car stumbles and hesitates sometimes like the timing is off, and if I hit full throttle at low rpm's some black smoke comes out the exhaust. If It does not have a chip then what could be causing the bad performance.
Old 07-18-2007, 12:35 AM
Wipeout
Not Special
Wipeout's Avatar
O2 sensor (probably my favorite answer lately), and vacuum leaking, maybe?
Old 07-18-2007, 03:50 AM
Apex944
Apex944's Avatar
Possible bad injector or fuel pressure regulator or fuel pressure damper making the car run rich.
Could be the O2 sensor also, making it run rich.
Have you had a tune-up done? Cap, rotor, plugs, wires, fuel filter, etc...?
Does it only stumble and spit black smoke when flooring it?
Old 07-18-2007, 04:25 AM
amet
amet's Avatar
Hi all,
I am not sure how you can check it , but you can adjust it on the DME.
Here is the link....
http://www.frwilk.com/944dme/fqswitch.htm
Good luck
Zeljko
Old 07-18-2007, 05:07 AM
sillbeer
sillbeer's Avatar
nice!
Old 07-18-2007, 05:10 AM
nh7cy
nh7cy's Avatar
that looks exciting!
Old 07-18-2007, 05:41 AM
Lizard944
Lizard944's Avatar
Also want to add the coolant temperature sensor to that growing list of potential headaches..
Old 07-18-2007, 10:42 AM
Yabo
Yabo's Avatar
Replace the engine temperature sensor, the one sending the temperature reading to the DME, rather than the one to the gauge. That can affect rich running..
Old 07-18-2007, 01:30 PM
tk's944
tk's944's Avatar
I remember one time when the car was at idle a lot of black smoke was coming out the exhaust, I think that day was really cold. Then I removed the spark plugs and they where completely fouled some worse then the others.
Old 07-18-2007, 02:02 PM
M758
M758's Avatar
You can have the cam gear offset by a tooth or more.
Quick Reply: How do you check and adjust engine timing?
