Adj. Rear Sway Bar Droplinks
Old 02-11-2008, 10:02 PM
  #76
black944 turbo
black944 turbo's Avatar
Got mine today, thanks.
I have a couple questions, I put the threaded end with the jam nut at the bottom (does it matter), also I assume that the spacer goes towards the control arm at the top and you use a washer in between the nut and sway bar from the original hardware, is this correct? This is how I just installed mine.
Old 02-11-2008, 10:18 PM
  #77
Reimu
Reimu's Avatar
Out of curiosity serge, did you send it to the address in the pm or did you go ahead and send what was on the paypal... I changed the address on paypal a few times but it never went through until a few days ago.
Old 02-18-2008, 01:14 PM
  #78
aben8057
aben8057's Avatar
-Remove old drop link
-Place spacer provided over top bolt
-Place drop link on top bolt with jam nut down
-Replace factory washer and nut
-Repeat for bottom using supplied bolt
-Repeat for other side of car
Old 02-18-2008, 01:53 PM
  #79
Wipeout
Not Special
Wipeout's Avatar
This would have been useful Saturday when I was installing them...but it looks like I guessed correctly.
Now if only I hadn't taken the damn eccentric bolt out when I started to work on it. Took forever to figure out what I'd done/how to get it back.
Old 02-18-2008, 02:22 PM
  #80
black944 turbo
Looks like I did it correctly, than. Seems to work great.
Old 02-18-2008, 02:24 PM
  #81
GodSpeed
Nissan Rulez
GodSpeed's Avatar
Just an FYI for everyone.
I ran these on my 944 for a good while and they are great!!! I never had a single problem with them. They are well worth what ever serge wants for them!
Dont ask, just buy 'em.
Old 02-18-2008, 05:31 PM
  #82
goldminer
goldminer's Avatar
Do you have any available at the moment?
Old 02-20-2008, 05:53 PM
  #83
Serge944
Serge944's Avatar
Not any at the moment. I will keep you posted. Thanks.
Old 02-22-2008, 04:04 PM
  #84
BADBERRY68
BADBERRY68's Avatar
I am ready also, let me know when you make more.
Old 02-22-2008, 07:55 PM
  #85
chrisc
chrisc's Avatar
Thanks Serge, got them the other day. Installed them and they compliment the trick custom front sway bar we just installed. The lean in the avatar is gone!
Old 02-22-2008, 08:25 PM
  #86
tomrc
tomrc's Avatar
Got mine the other day also, thanks, they'll complement my new suspension when I get it on.
Old 02-22-2008, 09:09 PM
  #87
schwank
Herr Unmöglich
schwank's Avatar
Roger arrival here as well. Thanks again... repeat buyer as they are a great value for a good part!
Old 03-03-2008, 07:15 PM
  #88
Keithr726
Keithr726's Avatar
Any update? I can't wait to get mine and install them.
Old 03-03-2008, 07:31 PM
  #89
Darwantae951
Darwantae951's Avatar
Install was super easy and they work great! Now all I need are delrin rear mounts to compliment my front delrin!
-Darwin
Old 03-07-2008, 03:18 AM
  #90
stefon
stefon's Avatar
Hello
I send you a mail , any available ?
Quick Reply: Adj. Rear Sway Bar Droplinks
