Flasher Problem
Sorry disappoint, this isn't about that "other" flasher.
Anyways my right front turn signal wasn't working, so i discovered that the ground around the bulb had completely corroded away. I replaced the ground with some wire that rubs against the bulb now. Only problem is that something changed. Now all turn signals flash fast, even though all bulbs are working. With or without the bulb i fixed in the socket, both sides are doing it regardless. But the hazard flashes normal still? Could I have fried the flasher unit?
