Pictures of the 944 S2 With 69k Miles I am selling
Here is the link to 90 pictures:
http://share.shutterfly.com/action/w...id=9DZNW7ZoyWw
Here is a sample:
69K miles. All paint appears to be original. Belts done about 4k miles ago. clutch at 45k, most maintenance recores from new. window sticker, tool kit, etc. car speaks for itself. I want the 10k i have into it. The wheels on the car do not come with the car. The car comes with the D90s and Dunlops that have over 70% tread left.
I said it before, if I had the room I wouldnt sell it. You can see my parking space in the photos. The turbo is in the garage. The Miata is in the front driveway. The S2 gets parked next to the corolla and the rendezvous behind the S2 leaving one space for others. I am a few houses from the beach. One space doesnt work, and the lot where i park the car is not what i would consider to be a Porsche friendly lot.
Here is a link to the ad for the Turbo https://rennlist.com/forums/showthre...96#post4234496
Here is a sample:
Tom,
Please shoot me an email with your phone number and best time to reach you, as I want to talk about the car. My email: isacarny@umd.edu. Thanks!
Here is the maintenance records.
The battery was replaced in April 2007. $85
SM Motorworks in New Hyde Park changed the oil, cam tensioner pad and oxygen sensor at 67,358 miles in February 2007$823.
The mechanic at SM is Pete. Pete is the Metro NY chapter of PCA's technical advisor for a few Porsche models, I believe including the 944. Pete also gave the car a thorough look over in February.
Pinnacle Motor Works in Stirling NJ replaced the filters, plugs, thermostat, belts, water pump, and rollers (total $2,323) at 63,709 mles in Jan 2006.
Rolfs in Summit NJ replaced the ignition switch 61,147 miles in August 2005 $491.
Rolfs did a belt/waterpump job on the car at 59,305 miles in December 2004. Included on the bill is a timing belt tensioner PN 944 105 067 16 $300. I was not sure if this was the cam chain tensioner so I had the pad changed in January 07. The total of that bill was $2,764.
I skipped some smaller receipts.
Rolfs replaced the air flow meter at 52,269 miles in September 2003 $ 678.
The clutch, fuel pump relay, crankshaft seal, cap/rotor/plugs were replaced at 46,633 miles by Rolfs in September 12, 2001. $2,708.
The muffler $737 part, exhaust tip $33 part, wires $207, were replaced by Rolfs at 46,391 miles in June 2001 Total $1,304.
A blaupunct CD changer and cassette/radio (Malibu) was installed in January 2001 by Interstate Cellular in Springfield NJ for $673.
Rolfs replace brakes $241 at 42,241 miles, March 2000
Rolfs aligned the car and replaced a radiator hoses belts, rollers, fuel/air filters/plugs, water pump, etc at 33,861 miles in April 1998 $ 1,995.
Rolfs replaced tires, and the thermo fan switch at 29,282 miles in April 1997 $475.
Rolfs replaced the sunroof lift at 27,631 miles in December 1996 $ 697.
Rolfs aligned the car and adjusted the sunroof cables at 26,898 miles in October 1996 $275.
Rolfs aligned the car at 22,635 miles in June 1995 $150.
Rolfs aligned the car at 18,000 miles in April 1994
Rolfs replaced the front brakes at 16,075 miles in July 1993
I have receipts from June 91 with 3,570 miles. The car was sold by Jack Daniels 5/31/90.
