and the diagnosis is..............
I bought an 88 944 this weekend with the hopes of making it a driver but there are too many parts missing and bent/rusted so it is the next in a long line of parts cars. It has the 220 option (lsd) but I am perplexed. With the back end up on jacks I spin one wheel and the other doesn't even move. Doesn't look good. The clutch is on the floor as I was told the clutch is out but that can't be the issue can it? Thanks in advance.
Even if it's in neutral, the wheels should spin oppositely as long as one wheel is left untouched.
OT: Hey Bill (2BWise), how'd you guys end up doing at Comp? We were...less than ideal. Our PE took a crap and we didn't have enough time to retune the car, so we had to run w/ an old map we had made for last year's car...it was terrible.
Originally Posted by plyhammer
Last LSD I had both wheels spun the same direction when up on jacks and in neutral
Car off the ground, transmission in neutral, spin one wheel forward, if other wheel spins forward in the same direction, it is LSD, if it spins the opposite direction, it is not, or it is broken.
Regards,
Russell
Regards,
Russell
The tires should spin the same direction with LSD, when turning 1 wheel only by hand, and in opposite directions with non lsd. In high mileage transaxles, the clutch packs in the diff will wear out, and allow them to slip. Hence, you will turn one wheel by hand, and the other will not turn.
If you pop your cv axles loose, and spin the output shafts by hand, the other will probably spin, because it no longer has the weight of the other wheel to rotate.
Regards,
Russell
Regards,
Russell
What type of "LSD" are you familiar with?
Factory 944 is a ZF (brand) Clutch type, which is a true friction type limited slip differential. 40% locking loaded, 40% locking unloaded. Even a slightly functioning (very worn out) stock 944 factory LSD will turn the other wheel the same direction. This method is testing the unloaded lock. To test the loaded lock, you need to turn the input shaft (engine, driveshaft).
Torque biasing diffs (which are not limited slip diffs) will have approx 0% unloaded lock, so it basically functions as an open diff when unloaded. The other wheel will either not move, or spin in the opposite direction.
