Shout Out for NorCal 968/944 owners
I need help big time. I have broken my screwdrivers trying to get the grease cap off my front wheels and I give up. If there is anyone with experince working on wheel bearings who can come up and help me I would greatly appriciate it. Afterwards I could treat to dinner at one of the many resturants in Vacaville.
Something does not sound right, the grease caps should not be on that tight. I use a large standard blade screwdriver angle the handle towards the rotor and strike the handle with a rubber mallet. A couple of love taps, rotate the rotor 90 degrees and repeat, rotate another 90 deg. and continue... It will not take much effort to remove them. Hope this helps.
I use a large pair of channel-locks usually, adjusted out to it's widest range and positioned at 0 and 180 deg. Mine are usually a tight fit so it only comes out when you creap it back and forth - a tedious process with a screwdriver but once it is 1/4 inch out from flush, it comes out easy.
