cheapest & easiest way to tow a 944 15-20 miles?
For 15-20 miles, you should be fine with the rear wheels on the ground.
The issue is that supposedly, if you tow the car for a long distance (with the rear wheels on the ground), you can really heat up your tranny oil, since without the motor running, it is not circulating. I don't know how true that is.
944J - where are you located? There are lots of PCA members who tow their cars to the track -- maybe they can help you out...
-Z
-Z
-Z
-Z
Well the tranny oil heats up whether the car is running or not; on a manual transmission I'd expect it to be perfectly fine as long as the oil viscosity is appropriate. With a manual in neutral the differential will be spinning, yes, but (not sure) I don't think the gears are moving at all.
Call 3 or 4 tow shops for estimates. And, if you have a friend with a truck or big car with a tow ball, ask Uhaul what their 2 and 4-wheel car carriers. Even better, if you can find one of Uhaul's old tow bars (triangular thing, attaches to f. bumper), to buy--eBay or Craigslist, --do it even cheaper--but drive slow. Uhaul discontinued those bars not because of failures on the road, but because people backed up with them, mangling them, sometimes whacking the towed car, too.
-Z
-Z
need to get a car from oxnard to ventura
whatever you do make sure the safety chains are on that thing, i just had my car roll off a uhaul trailer and if i ever tow it again i will check everything 5 times before driving away.
special tool will know what im talking about it rolled right down his driveway
From: Albany, CA: celebrating 100 years of independence from Berkeley, CA
Cheapest: take the bumpers off and flat tow using a tow bar attached to the bumper shocks. Certainly not the easiest way to trailer, though....
